I upgraded 5.5.0.4. There is no shutdown option - only an option to reboot. I normally prefer to shutdown and swap SD cards before restarting. Is this a faulty installation or did they change this for some reason?
Thanx.
hi guys, help pls ... i'd install cm9 0.6.14.0 using cwm 5.0.2.6, i want to know if the cm9 gonna work good on my phone i am seeing some issues on it, like frozen phone , voulme problems, gps, rebooting phone, browser, is this because the cwm o normally cm9 alpha issues or i have to update the cwm to 5.0.5.4 if i have to do it, how i update it. oh! can i update the cmw with cm9 latest version already on my phone? thanx for ur help
thank u mantera i will try ur suggestionsWeird. I think it was removed. I'll have to look into it when I get a chance.
cm9 works fine. If you are having issues as you described, it's usually caused by one of the following:
1. A bad flash -- solution: rewipe your phone in cwm and reflash the rom.
2. Apps that are causing the issues -- solution: rewipe the phone and reflash the rom then slowing reinstall your apps one at a time to see which one is causing the issue.
3. faulty hardware - get a replacement from whereever you bought it from if you got their insurance plan, otherwise get a replacement from vm.
Hey manures what all repos need to be on the ics branch to build this? I tried it with just the recovery repo and it failed spectacularly lol! I'm figuring maybe the build and bionic. I'm hoping not too many cause I want to build this recovery without having to pull full ics source down!
To tell you the truth, I'm not exactly sure offhand on what other repos that the bootable recovery repo is dependent.
However, I think since you already have the gingerbread source, you might be able to just switch to the ics branch in your current bootable recovery branch and I think that should build ok for you. Of course, if you want my changes too, you'll need to either cherry-pick my commits or sync to it.
Unfortunately, I'm not in a place where I can look into this further for you atm. Sorry.
Edit: And I assume the "manures" to whom you are addressing your question is me...
Hello all!
Just joined, so total n00b on this stuff (though *very* computer skilled).
My phone does not seem to want to boot into download mode - even when I hold both buttons down correctly, it still boots normal (and no vibration)
Any ideas?
Thanks! (Very anxious to try CM7!)
Nevermind - stupidity in overload - was using Volume Up, instead of Dwn, lol
Ok, now I'm worried that I bricked my phone
I DID do a Nano backup with CWM, but then I installed the wrong CM7 mod
I realized that after it wouldn't boot past the "M" logo. So I removed the battery and booted back into CWM and restored the backup.
The restore registered successful, but it still won't boot past the "M" logo :`(
Any help?!
Ok, had a spare SD card and my old Triumph unit, so copied the files over to that card and swapped the cards. However, after applying CM7, I no longer have my Contacts or Messages.
How do I get them back?
Ok (lol), so I can still copy my Contacts from my old phone to my new phone via the SD card - but what about the messages?
Thanks!
lol... i just made the same mistake. I get so excited that i forget to
read the instructions hahaa!
would getting cwm root my triumph?
My triumph doesn't recognize usb or chargers,im using another triumph to charge the battery for it. How can i access the mobile partition with no usb access?
