Nice! I tried to do it myself but I couldn't get it to compileUpdated OP (to include link)
Updated TWRP Recovery (v2.8.6.0)
https://www.androidfilehost.com/?fid=24052804347758728
Wiping is a lot faster now.
MTP and ADB both work in recovery
I get no sim no matter what
will this work Virgin mobile to or just with boost?here it is..replace the one in the ect file under system files
Not trying to be a noob but when i tried to install this on my Volt (ZV5) in TWRP it failed, and how comes the ROM is only 200MB?
I am coming from stock rom and i wiped Dalvik Cache, data, and i think systemdid you do a full wipe before hand?...are you coming from stock rom?
I wiped everything except external SD with Lollipop TWRP and still got an error when trying to install CM12Make sure you are using twrp for lollipop.
Then you need to wipe everything except external SD card before you flash
CM11 installed now but i havent tried installing CM12 yet, i do have the lollipop TWRP installedi had the same problem initially ...try flashing the cm11 build first...do a normal wipe via twrp...then flash the cm12.1 build.....trust me it will work...i know its an extra step but hey it works..and has been tested....be sure to flash the updates twrp as well posted by bad mofo
Become an Android app developer for just $23 with the Android M Developer Course! | AndroidAuthorityI know this is not the correct place to ask this but I really want to work to become a Developer. I am 17 and my school does not offer classes that relate to any type of programming or anything of the nature. I need help getting started as I don't know where to begin. I own the LG Volt and If someone could direct message me that would be wonderful.
I did what ThaAdvocate did and it worked, im flashing Gapps now, everything is ok except Youtube, which I NEED, so until HQ videos are fixed ill stick with the stock ROMMaybe you have a bad download?
sounds like you're doing what you need to do...
http://www.androidauthority.com/android-m-developer-course-616441/
Seriously this is the best deal your gonna get
Lol......ok.People have already contacted me and I am already working on my own CM12.1 ROM for lg Volt. I am using alot of what Badmofo has already done. Why spend money when there is unlimited resources online and people willing to answer my questions.
Forget it I just noticed I have to let go of the buttons lol. Anywho, why am I not getting past the boot logo?After flashing I'm stuck on the boot animation (blue guy) and when I try to go to TWRP with Power & Vol down it says 'Factory Reset Processing" What did I do wrong?
Try wiping your caches (cache and dalvik) in TWRP. Also, the blue guy is Cid, Cyanogn's mascottForget it I just noticed I have to let go of the buttons lol. Anywho, why am I not getting past the boot logo?
