Root cm7 and apps to sd
mikem0269
Android Expert
How do i do apps to sd on cm7? Do i need to load something or just run a comand in TE sorry im spoiled from the newer roms having this built in.
thanks
its been so long since i flashed cm7. i believe though you need to flash dark tremors. i do not think it has a2sd. i could be wrong though. you have to have your card partitioned first.
Its partitioned. Yea i dont remember either. And are you on here 24/7 LOL
I always get a responce from you with in 5 min. You are the best.
You could just run the se2(I think is the name) from android market, does the same thing as dark tremors but with no hassle. It only works with cm7 though.
its s2e, and it works with cm9 as well, hmm nice.
I read the comments on the market page for it, and that seems like nothing more than a hassle. Anytime something can be done manually it should be done manually, that way if there's a hiccup you know why. Didn't anyone learn their lesson from rom manager?
I have used it albeit briefly I never had problems, but it looks like the version there now is a very recent build any changes could have been breaking something.
