bads3ctor
This is an ALPHA build of Cyanogenmod 7 from source.
Please post here only with bug fixes or logcat output. Thanks.
Do not flash these files unless you know what you are doing.
I am not responsible for bricked phones or hurt feelings.
Do a CWM backup before flashing.
__________________________________________________________
CM7 for Boost Transform Ultra: CM7_TransformUltra_Boost_Alpha1 - Minus
md5sum: e388214d8ff32f53f603ec0ad434c7ed
ChangeLog:
CM7 for Sprint Transform Ultra: This will be zip to update CM7 for the Sprint TU.
md5sum:
ChangeLog:
CM7 generic zip: cyanogen_transformultra-ota-eng.bads3ctor - Minus
md5sum: 64784944a27abeba8c199e2cbbc47a4b
___________________________________________________________________________
TU Boost kernel: PR_Alpha2 - Minus
md5sum: f9028cf93a11f8fbd29f974593d919b4
TU Sprint kernel: PR_Sprint_Alpha1 - Minus
ms5sum: eaf917952594ed81b5a57ebd6cc315da
Look here for more information: http://androidforums.com/transform-...-transform-ultra-developers-testers-only.html
Bobz kernel now compatible with CM7: http://androidforums.com/transform-.../495512-over-clocking-kernel-sph-m930bst.html
Instructions:
CM7 zip:
- penguinrepair for his TU kernel. CM7 TU would not be possible without his kernel.
- interdpth and DRockstar for all their earlier work on the TU
- requisite0 for his help with the new kernel
- chevanlol360 for his edify coding skills
- KydDynoMyte for testing alpha builds and posting logcats
- BobZhome for making his kernel compatible with CM7
ChangeLog:
- Added stock Boost build.prop settings and ro.telephony.network=4
- Added stock Boost rmt_storage
- Added stock Boost libsec-ril.so and libsecril-client.so
- Added stock Boost /system/etc/wifi/*
- Added stock Boost macloader,mfgloader, and wlandutservice to /system/bin
- Added stock Boost softap_event,drexe,orientationd,geomagneticd,btld to /system/bin
- Added stock Boost /system/vendor/*
- Added stock Boost /system/usr/keychars and keylayout
- Added stock Boost /system/lib/hw
- Added stock Boost /system/lib/liboverlay.so needed by /system/lib/hw/overlay.default.so
- Added stock Boost /system/lib/libloc_api-rpc-qc.so and libcommondefs.so needed by /system/lib/hw/gps.default.so
- Fixed /system/usr/keylayout/vital2-keypad.kl and sec_jack.kl to work with CM7
- Added new Cyanogenmod boot animation
- Added stock Boost /system/etc/permissions
- Deleted /system/app/RomManager.apk(force closes)
- Deleted SuperUser.apk(force closes)
- Added chevanlol360's device verify code to updater-script
md5sum:
ChangeLog:
Instructions:
CM7 zip:
- Boot into CWM Recovery
- Copy CM7 zip to SD card
- Use "Install zip from sdcard" to flash it
- Unzip kernel and copy the directory to CWM backup directory
- Restore it using CWM "Backup and Restore"
- Always do a backup before flashing anything
- The stock kernel will NOT work with CM7
- When returning to stock Gingerbread, make sure you have the stock kernel or Bob's OC kernel flashed
