Root Cm7 hot fixs
after i install cm7 beta4b what hotfix do i download and install the only hot fix i see is
Beta 4b Hot Fix 1, old omx libraries to fix issue with Netflix 1.2.2, block ad host file, fixed prop version
THIS IS FOR THE PREVAIL
What you need is right there it is labeled beta4b same as the rom correct.
At this moment there is only one hot fix and so its hot fix 1
If more come out they will no doubt be labeled hotfix 2 and then hot fix 3
If you use netflix and have problems then you may want to add the omx zip but until that becomes an issue do not worry about it.
