the question is: is easier to modify or to replace?
also who would be capable of doing this?
I know nothing of programming or developing anything
Not sure if more than 2 points would work on the MT. The hardware may only be able to detect 2. And even if it detects more than 2 or hacked to do it by software (not very likely), then there may be the problem of crossing axis (which affected a lot of older 2-point touchscreens.)
Currently on the MT, the 2 touchpoints have a problem of "snapping" together when they're close. So with more touchpoints, there's more opportunities to snap together. (imagine a small area filled with a bunch of magnets, it's hard to manipulate them individually until that bug is fixed.
I think isaac fixed that "snapping" issue with his update touchscreen driver, I dont encounter that problem at all.
that snapping problem makes it easier to zoom in maps without rotating the map accidentily, but it completely destroys any hope of gaming on the phone. Modern Combat 2 plays PERFECTLY, but its absolutely impossible to dual thumb and line up any shot becuase the thumbs sit by the same axis and constantly ruin the aiming.
same for minecraft mobile, BIA2, and most emulators.
is that snapping thing a hardware issue? I cant imagine it is, seems like something good drivers can fix, but I dont know these things
NINJA'd by Whyzor!!!! Welcome to the club!i still experience the snapping problem... try running a multouch test and you will probably see when the axis cross it snaps together untill you get far enough away...
so you're saying that adding a point might just make it worse rather than better, that just sucks
