Root CM7 ROM Manager?
An UrgeTo Dance
The Hero of the Winds
Hey everyone I am running CM7 with RA recovery so I don't really use ROM Manager and don't really want it, so I was wondering if I can uninstall it. I went to uninstall it from the market but it only gave me the option to uninstall the updates so I was wondering if I could uninstall it through TB or if I should just leave it.
Yeah, it should be fine. It's probably installed as a system app (in /system/app). That's most likely why you can't uninstall it the normal way. Either remove it with tb, or just delete it from /system/app manually.
