Root Collin_ph_battery Tweak
I used it for few days with Warm RLS3. Totally not worth it. I disabled it last night, and today, my battery life was SO much better. Like, double. I also use SetCPU with profiles to save when the screen is off.
I highly recommend NOT using it.
two days with it now and most likely will get away from it. I had some time without signal though so we will see after maybe two more days in an area that I know I have good signal
Did you uninstall setcpu before trying the tweak?
I'm curious of this as well. As I understand it, you should NOT use SetCPU with the tweak. Freeze it with Titanium if installing the tweak.
Agreed, if you are going to use the tweak, uninstall setcpu and/or any overclocking apps. You can set frequencies within the tweak
