Help Color Codes Needed
Hello everyone,
Since getting my new ROM (AOKP build 28) I have been trying out a ton of things including setting the colors to be different for things like my soft keys and clock. When I choose a color I get the slider on the right to pick the color and the density I think on the left in the large window. There is a number that gets assigned in the bottom. I wanted to know if there is a list of color by numbers (sounds like a sting song) so I can match things or at least not be too far off when I want say red
Thanks
-S
^^GMB!! Haven't seen you around for awhile. Good to see ur rocking the Nexus. On topic, I've been trying to perfect ICS blue. Best I've come up with so far is FF4A9DCD. Not sure if its perfect but its as close as my eye can get.
IBT, whats up man!? I got lost in Apple's walled garden for a while there..... :o
I have recently become stricken with NateModz RED theme. I used to really like the ICS blue until the first time I used Nates RED theme and saw how much the red really pops on the sAMOLED screen.
Nate uses #d30203 for the text and #ff0000 for the rest of the red themed elements. I always change the battery bar and navigation buttons to #ffff0000.
RED FTW! :p
Very off topic, but nice to see the "Old" Incredible crowd around again....
and on topic...the decimal codes rocked, any similar listing for a hex set? (yes I will go Google it now LOL )
Officially, it's #FF33b5d5 ((EDIT: Tim K is right, it's #FF33b5e5, I didn't proofread.))
It's what I've been using, and it matches the unchanged elements perfectly, as far as I can tell.
Everything I have seen says that it is 33B5E5 and was pulled from the source code. Where are you coming up with 33B5D5 or is that a typo?
