This is a guide to walk users through installing the Android SDK and using fastboot and ADB. The unlocking and rooting process for HTC devices can be a little daunting. We discovered this with the Evo 3D, so I wrote a similar guide to this one in that section to help ease the confusion. I hope to continue the tradition with this guide in this forum.
So let's get started!
Note: This WILL wipe out your settings, apps, et cetera. Please make any/all necessary backups before proceeding.
Due to popular desire for a simpler guide, I've decided to make a "skinny" version. If you need further explanation, please see post 2 for the "full" guide.
sanman1185 has made a video that he has posted in this thread: http://androidforums.com/evo-v-4g-all-things-root/584703-how-root-video-htc-evo-v.html, click show to see the video:
Step 1) How to install and configure the Android SDK
Step 2) Move files to where they need to be.
Step 3) Opening the command prompt and getting ready for entering fastboot.
Step 4) Unlocking with HTC Dev
Step 5) Let's install then boot into recovery!
Step 6) Before you do anything, it's time to make a backup.
Step 7) Flashing the ROM
Quick Guide) Flashing another ROM
(Optional) Installing 4EXT - Highly Recommended!
(Optional) Getting S-OFF - Highly Recommended!
Based off of my Evo 3D root guide found here: http://androidforums.com/evo-3d-all...shing-evo-3d-roms-kernels-using-fastboot.html
Some of the commands in this guide were found here: [GUIDE] HTC Unlock Hboot 1.50 + TWRP Recovery + Root + Flash!! [9.11.11] - xda-developers and http://androidforums.com/evo-3d-all...lash-recovery-image-via-fastboot-sd-card.html. I just sought to make a complete newbies guide version of it.
First, you need to download a lot of software. So here are the download links:
1) HTC Sync
2) TeamWin Recovery Project (TWRP) version 1.1.1 - Recovery - Get the IMG version, not the ZIP version. Rename this file to "recovery.img" if it appears as 'recovery-twrp-shooter-1.1.1.img'. If it appears as 'recovery-twrp-shooter-1.1.1' then just rename it to 'recovery'.
3) The stock ROM. Grab the ODEX version for as near to stock experience as possible.
4) Mini-SDK Then extract Mini SDK to C:\sdk-tools.
1) HTC Sync
It doesn't really matter where in the SD card you put it. I just recommend you put the Stock ROM + root in a folder named ROMs and the recovery file needs to go in the C:\sdk-tools directory on your computer.
Now, click Start and either open Run, or click in the text box in your start menu. Then type 'cmd'. You get a command prompt. Now we need to go to the Mini SDK folder. If you installed it in the same directory I did, you can copy (or type):
Code:
cd C:\sdk-tools
If you haven't already unlocked your bootloader using HTC DEV Unlock we will do so now.
Step 1) Getting into fastboot.
Go to Settings > Applications > Development and check USB Debugging. You'll need this enabled for the adb reboot command.
Connect your phone to your computer. From now until you're done flashing your ROM, you will not disconnect the USB cable.
Now, in the command prompt, type (or copy and paste):
Step 2) Getting the device identifier token and then flashing unlock_code.bin
Type the following command in the command prompt:
A long text boxes will come up. Right mouse button click on the screen and click mark. Then highlight the token from <<<< Identifier Token Start >>>> to <<<<< Identifier Token End >>>>>, like shown:
Do not highlight info or bootloader or any extra spaces or text. Once you have done that, right click again and hit copy.
Now go to HTCdev - Unlock Bootloader and fill out the forms and paste the code into the device identifier token box and submit. If you're having trouble with the HTC dev site, please disable any pop up blockers, anti-viruses, and/or firewalls (temporarily). You'll get an email (check your spam folder) with your unlock_code.bin. Once your receive it, transfer that file into your C:\sdk-tools\ folder. Now go back to your command window and type:
The unlock token should give you a prompt to accept the unlock code or not on the phone. Push volume up to accept. The phone should now reboot for you (so that you'll be back in Android). If it doesn't you can do it manually by reinserting the battery and then holding Vol down + power. You should now see UNLOCKED displayed at the top. If so, congratulations, you are now unlocked!
Code:
adb reboot bootloader
Code:
fastboot oem get_identifier_token
Code:
fastboot flash unlocktoken Unlock_code.bin
Now we need to get back into the bootloader.
To do that, type this in the command prompt:
Once in the bootloader (HBOOT) type (or copy):
This now flashes TWRP 1.1.1 that we downloaded earlier.
Wait for that to finish, then type (or copy/paste):
Code:
Code:
fastboot flash recovery recovery.img
Code:
fastboot boot recovery.img
I'd recommend that you backup:
System
Data
Boot
Wimax
Everything else is optional, in my opinion.
System
Data
Boot
Wimax
TWRP 1.1.1 has capacitive buttons that work, so hit the back button. To flash a ROM/Kernel, do the following:
1) Go to Wipe Menu
A) Wipe Cache
B) Wipe Dalvik Cache
OPTIONAL) Wipe Everything (Data Factory Reset) - This is useful if you have problems with flashing certain ROMS. Some ROMs require this before flashing. For the stock ROM, this isn't necessary. But if you're on HBOOT 1.5 and used HTC Dev, you did a factory reset anyways, so it can't hurt.
2) Go back and now go to Install Zip.
A) Choose Zip
B) Go to the folder ROMs/
C) Select the ROM you want to flash (the stock ROM or SU patch for example)
D) If you're flashing another kernel, you would find your kernel and by selecting Choose Zip and finding the kernel file. The kernel must be selected AFTER the ROM is selected, or else the kernel built into the ROM will overwrite the kernel you want to flash.
E) Check 'Reboot After Successful Flash' - this is just a nice feature of TWRP that makes it so you don't have to pay attention to the flashing process.
F) Flash Zips Now
3) Sit back and relax. The flash is going to take 3 or so minutes. Then it'll reboot. The reboot will take 5 minutes or so and will always take 5 minutes or so every time you clear out the cache and dalvik cache. It is normal.
If successful, congradulations! You flashed a recovery, ROM and kernel by using fastboot!
1) Go to Wipe Menu
A) Wipe Cache
A) Choose Zip
F) Flash Zips Now
Let's say you want to flash a new ROM. Here's how to do it:
If you're starting in Android, connect your USB cable. Then click Start and either open Run, or click in the text box in your start menu. Then type 'cmd'. You get a command prompt. Now what you type or copy/paste will depend on your version of Windows and where you installed the Android SDK.
Then type:
When the bootloader appears, type:
You're now in recovery. Make a backup if you wish, then:
1) Go to Wipe Menu
A) Wipe Cache
A) Choose Zip
C) Select the ROM you want to flash. If you chose just to download the SU patch or the stock ROM + Superuser, this is where you would select the file.
F) Flash Zips Now
If successful, congradulations! Enjoy the new ROM/Kernel!
Code:
cd C:\sdk-tools
Code:
Code:
1) Go to Wipe Menu
A) Wipe Cache
A) Choose Zip
F) Flash Zips Now
There is a recovery that makes it really easy for HBOOT 1.5 people to flash ROMs and kernels. It's called 4EXT Touch Recovery. If you're familiar with ROM Manager, you'll love this app/recovery. You can control every aspect of your phone's recovery from an app. Best of all, even with S-ON Unlocked, you can flash kernels without using fastboot. Just go to their website to get the free version that comes with a 3 day trial of the full version, or get the full version. After you're done with the trial, I'm sure most of you will want the full version. It makes everything easy. I use it, too, and I'm on HBOOT 1.4
To install, download/install the app (free or paid) and open it. Give it SuperUser permissions and then click through all the pop up dialogs. Push the install button at the top. Indicate if you are S-ON or not (if you had to unlock with HTC, then you click yes). And it installs. And after 5 minutes of running the free version, your trial for the full version starts. So come back in 5 minutes and reload the app (by pushing the back button until you get back to the desktop and relaunch). If you're on the paid version, you can just start using the app immediately.
Now go to recovery and you can do everything you would normally do in recovery, but it's fully automated once you click start after selecting all your options. Including making backups, wiping caches, and installing ROMs. Remember to support the developers if it makes things a lot easier for you!
What is S-OFF?
S-OFF means that bootloader security is off. This allows you to flash images to the /boot partition. Simply put: It lets you flash whatever you want without using fastboot or specially enabled recoveries. It makes things much easier to do but it also takes away the security that keeps you from bricking your device. If you do S-OFF (it is recommended), remember to check everything that you're about to flash and make sure it's for the Evo V.
http://androidforums.com/evo-v-4g-all-things-root/558583-s-off-juopunutbear-s-off-beta-release.html - S-OFF while staying on HBOOT 1.5. Requires you do a 'wire trick' to ground out a signal at a certain point. May be easier than temporarily bricking your device.
