does the stock recovery allow flashing of superuser.zip? o:
No, you need a custom recovery for that.
Also, with all the feedback being positive, I'm going to remove WIP status and put up the wire trick for S-OFF and 4EXT as confirmed.
Seriously, 4EXT is highly recommended!
OK, what does it mean to have S-on or S-off? This is after all a thread for newbies!
Just added the definition to the guide in the S-OFF section
S-OFF means that bootloader security is off. This allows you to flash images to the /boot partition. Simply put: It lets you flash whatever you want without using fastboot or specially enabled recoveries. It makes things much easier to do but it also takes away the security that keeps you from bricking your device. If you do S-OFF (it is recommended), remember to check everything that you're about to flash and make sure it's for the Evo V.
