I'm not sure how useful this might be since I don't have a N2 yet to play around with but is there a setting to sync contacts? If there is have you tried turning that setting off and seeing if that helps? There might be a setting for that in more than one app too... like I said, I don't actually have the phone yet so I'm just guessing.
It syncs email, it syncs calendar. Only my contacts stop. I have turned off just the contacts and back on and it fails to recover. I have to remove the account and add it back to make it work. I haven't tried to restart the phone itself though or do a full reset which it is getting close to me trying.
My old iphone 5 is starting to appeal to me again because I never had issues with it.
It's starting to come to light....
Do the people that have these contact loss problems running some sort of call blocker app?
For instance, I am using an app called CALL BLOCKER. Someone else who is also seeing their contacts disappear is running the same app.
Just want to find out if there is a common thread here as to why this problem is happening. For now, the call blocker app seems to be the best lead.
Im having issues of my contacts disappearing as well and im using call blocker too! They usually come back after a reboot....quite annoying actually but using call blocker is a great app that i use in my business...![]()
+1 ... Thx, this worksMay not work for you but I can always quickly recover by 1) starting Application Manager, 2) selecting the "All" tab at the top, 3) scrolling down to "Contacts Storage", and then 4) select it and "Clear Data". After doing that my contacts start syncing withing a minute or less. No need to reboot (though that also works for me).
Hi, l had the same problem. To fix the problem I deleted the last couple of apps that I downloaded n that workedI am on Jellybean 4.1.2
Anyone having a problem with their contacts disappearing?
I mean...completely disappearing.
When I reboot the phone they all come back, but at some point during the day they just totally disappear and my address book is empty.
