ICS still has bloat. Either way root and then freeze it with TB.I'm about to make the jump too, I am so sick of waiting.
Plus, I cannot stand the VZW bloat.
You can freeze bloat without root.![]()
How do you check your CPU speed? 1g or 1.2g?
cat /proc/cpuinfo
From terminal emulator (or via adb shell when connected to your comptuer):
Runand if the BogoMIPS value is less than 2100 you're at 1.0 GHz.Code:cat /proc/cpuinfo
Or, install and run http://play.google.com/store/apps/details?id=com.aurorasoftworks.quadrant.ui.standard and then go to the System Information selection and it will relay the max CPU frequency
Everything works and works better, quicker than before.so how's it looking, and is the phone 100 % functional.
everything works??????????
How do you take a screenshot and where is the native utility?Only 'bug' I've been able to come up with is that the native screenshot utility makes a camera click noise even if your camera is set to not make the shutter noise.
ThanksBtw- you can take a screenshot by pressing the power button and volume down button simultaneously.
How about flash vids using the browser? Did you come across a fix?
