D
Deleted User
Guest
i've rcently changed ROMS and liked the keyboard on the previous....is there a way to get the virtual keyboard from one ROM to another?
is it an APK?
is it an APK?
is it an APK?
is it an APK?
I think I've made about 7 or 8 different ones...it only takes a couple of minutes. Even made my wife one and used MS Paint to create a .bmp file with her name to match here pink themed phone...no screenshots of that...but a nice touch.
I think so...but I wouldn't recommend it for the most part cause depending on what ROMs your going to and from, there could be compatibility issues.
I would recommend this site here: http://www.gimpsta.com/themer/index.php
This site will let you design your own HTC IME keyboard (i.e. the Incredible's virtual keyboard). It is a great keyboard and YOU get to personalize the keyboard the way you wanted it. I'm bored so I decided to show off my Sapphire support...so I created a keyboard to go with my Wallpaper
And here are couple more I made just to give other examplesI think I've made about 7 or 8 different ones...it only takes a couple of minutes. Even made my wife one and used MS Paint to create a .bmp file with her name to match here pink themed phone...no screenshots of that...but a nice touch.
