I am also having the same problem, I can not use my ringtones for my contacts, and this suck, I have to listen to the same ring tone every time different people call me, Come on Android, Please someone help me!!![]()
Please export your contacts to your SD card then import your contacts to your phone. Now you can cutomize your ringtones.
My problem is, I dont understand what you mean by.. Just export your contacts to your SD card?? excactly how do I do this? use FutureDialSuite? how?
The forum's search function and the Captivate FAQ (a forum sticky, mentioned in many users' signatures and in most threads) is your friend. Always best to check there first.
In addition to this, once you are home, find your media folder, open it then tap on audio.
I too have had this problem, and I solved it. I am now able to use custom songs on my phone from the music player as incoming call ringtones. Here is how to do it. First you will need to download Astro! file manager from the market. Secondly, you will need to have your custom music placed in the downloads folder of your android device. Thirdly, open up Astro! and navigate to your music (/mnt/sdcard>download). Hold down on the selected file , tap on edit, then tap on copy. Navigate back to the root files be pressing the home icon at the top of the screen in the application. In addition to this, once you are home, find your media folder, open it then tap on audio. You should then see a folder that says notifications. Once you are here, create a new folder titled "Ringtones". Open your newly made "Ringtones" folder and hit the paste button to move your music. Now to be able to select your song for a incoming call ringtone, hold your selected file, hit edit, tap on rename, then delete the file extension .mp3 or .mpga and change it to .m4a then hit save. Finally you are done! Exit out of Astro! by hitting the home button on your phone, going into settings, clicking on sound, clicking on voice call ringtone, then select your custom song. I hope this helps you guys out![]()
1. Is it less than 300kB? (It has to be. Use Ringdroid to crop the file.)
2. Is it in the right directory? (/mnt/sdcard/media/audio/ringtones) I don't know if this really matters, but that's where all my "custom" ringtones reside.
3. Were you able to use that same mp3 in 2.1?
