I am not responsible for any damage that may occur at any time to you or your phone
ok on this thread i will explain how i got cwm to work on my phone
(i learned to do this after lots and lots of trial and error) any ways lets get started.
First off start by making sure your on FI22 (if not update your system via Settings>System Updates)
Next Root your Phone like this:
step 1: Download ODIN and install it
Step 2: Download and install Kies
Step 3: Grab the AGAT Kernel
Step 4: go into odin mode on your phone (Power + vol. down) and connect it to your pc
Step 5: Open up ODIN in administrator mode and click the PDA check box and browse to the agat.tar
Step 6: Click Start (when its finished your phone will reboot and there will be a yellow triangle. dont worry its nothing)
Step 7: download Super User and put it on your SD Card (it doesnt matter which one)
Step 8: Open up agat and select install zip
Step 9: Select the SU.zip you just dled
step 10: Reboot and your rooted YAY!!!
Edit: Ok so apparently the method that i first posted doesn't work so first off root your phone as stated above then flash this in ODIN (on the PDA slot)
Q&A
How old am I?
Well that was an irrelevant question to this post but i am 13 (JK) (but i really am 13)
And also a special thanks to guyphs for his root meathod that i posted here
Q&A
How old am I?
. Also to all new to flashing, you will need a kernel for whatever ROM you are going to flash. Meaning it has to be compatible with it. Like a Aosp/Aokp kernel for and Aosp/Aokp ROM. Most of agats are for ROMs based off of the stock image only.
