JamirAHudson
Has anyone gotten Google Now on tap to work ???
This ROM hasn't been in active development for a few months now. SorryAttempting to import contacts from vcard (.vcf file) crashes the app. Ive tried importing it by scanning it through the contacts app in itself and also opening the file manually, both crash the app. The same exact file works on other roms.
Im also getting other app crashes randomly. Other than that, been using it for half a day ;3 getting use to it, i used your old CM rom for ZTE but it was too buggy, hopefully this time i report the bugs hahaha
If you need logs or anything of the VCF file crash, could you explain how to get them? I'd love to contribute. THANKS
Oh, Im new here :3 it said last updated Sept. 8th, so I thought it was still active Haha but okay thankyou!This ROM hasn't been in active development for a few months now. Sorry
It's a as-is take it or leave it kind of thing
Te sirve el gps? lo siento, i don't speack inglish , you can help me? the gps dosn't workOh, Im new here :3 it said last updated Sept. 8th, so I thought it was still active Haha but okay thankyou!
I think one of the new updates on Pokemon Go was made to not work with rooted devices anymore. Whats your Pokemon go version?/ Creo que una de las recientes actualizaciones a Pokemon fue hecha para que no funcione mas con dispositivos rooteados. Cual version de Pokemon tienes?I need help you guys! The GPS dosent work ... and i need play pokemon go !! please help me!!!
Segui hablando asi, no te resuelve el probema y solo te haces el pendejo. Es entretenido.Pedazo de mierda, yo me refiero a que el GPS no sirve, no sirve el GPS, se muy bien que no agarra en dispositivos root pero el GPS no sirve para nada, en google maps no detecta mi ubicacion
A ti si te sirve el GPS amigo ?Segui hablando asi, no te resuelve el probema y solo te haces el pendejo. Es entretenido.
Would u mind sending me a copy of broken 4.9 dude. Id be very grateful. Been looking everywhere but it was all removed.yes that is my only issue aswell with both this rom and the broken os 4.9 other than that i don't have any real issues
have you tried the flamingo/redbull sensor fixes?I tried that it worked then it started happening again lol, no fix huh?
so, flashing the sensors or the xposed module did not work for you???Well I guess I need closed because this always limits me to only stock Roms that's why I swapped back, I need to figure something out
