Valery_18
i speak frenchValery doesn't speak english very well.
it's a question of time.i will soon contributeNo one is trying to make you feel stupid, but you ARE going to need to do a lot more reading before you should do any more flashing. And you ARE new to this forum. just because you have browsed before does not make you part of the community. When this conversation started you had 2 posts to your name, so please dont waste your time talking about being a 'future' developer. So far you have contributed nothing. Masterchief87 has helped me out personally in more than one forum for years now.
i understand. i was explaining that to him so he would understand your grammar issuei speak french
sorry if i misinterpreted what you said.First, I didn't call you an idiot or say anything about you at all. Second, when you are trying to convince someone that you are not an idiot, it helps to be able to use proper grammar. Things like spelling, capitalization, and punctuation are very important in situations like this.
Can someone post a link for broken os v4.8 for zmax please?
thank you so much man,I found what i was looking for.
check to make sure layers app has all permissions granted in app settings. if that doesn't work, try using root app uninstaller to uninstall layers, then reboot and reinstall it and try againI downloaded the new brokenOs version v4.9 for zmax and installed it.I have a problem with layers,i downloaded a layer theme and intalled it correctly with layers manager apk then rebooted my phone, but nothing has changed.System write protection is disabled.Can someone help me to fix it?
Thank you.I'll trycheck to make sure layers app has all permissions granted in app settings. if that doesn't work, try using root app uninstaller to uninstall layers, then reboot and reinstall it and try again
i did everything you told me,still doesn't work.check to make sure layers app has all permissions granted in app settings. if that doesn't work, try using root app uninstaller to uninstall layers, then reboot and reinstall it and try again
have you tried a different theme?i did everything you told me,still doesn't work.
yes i havehave you tried a different theme?
i would recommend taking it up with the developers. the best place to reach him is on Google+. Broken has a page somewhere.yes i have
thank you for trying to help me.i would recommend taking it up with the developers. the best place to reach him is on Google+. Broken has a page somewhere.
Are you serious?Latest version of Broken doesn't support layers anymore.
Yup. And I also advise you to go on Google+ specifically to "BitSyko Development" community and read the pinned post which will also have a link to a Substratum post that you should definitely read. Substratum is the new theming engine which the latest version of Broken does support.Are you serious?
Ok.i saw, but substratum isn't ready to use.Yup. And I also advise you to go on Google+ specifically to "BitSyko Development" community and read the pinned post which will also have a link to a Substratum post that you should definitely read. Substratum is the new theming engine which the latest version of Broken does support.
A stable beta version is out that you have to opt in for testing. There's videos in that community showing how Substratum works. But you'll have to use it at your own risk since it's only supposed to be out for developers and themers.Ok.i saw, but substratum isn't ready to use.
for the moment i want to use an another version of broken os like v4.8 or v4.5 which supports layers but i can't find it.I found a link but it said "error 404 not found" on androidfilehost.Would it be possible to upload one for me?I hope you will understand my english.They are saying it isn't ready for users, not because they want to keep people who aren't developers or themers from using it, but because they don't want 1,000,001 bug reports at this early stage. It has a few minor glitches but overall works pretty well.
