Y'all need to read up in our community , and the layers one. Layers is dead , there is something else called Subtrantumbefore i switched to this cm build begining of july, the last brokenOS posted on g+ still worked with layers manager from google play, but i had to specifically use that one. if i tried to open layers in settings before hand it would just crash.
it might be the layer you are trying to use... i can forsure state both neon green -layers theme and acid - layers discontinued both work fine
you probably have a wakelock. i never saw anything close to that. i would lose 1-2% overnight. there are apps to address wakelocksI love this ROM. Everything seems to work and have been using for a good month now. The only issue I've seen outside the sensor deal is some battery drain. In 12 hours I'm losing roughly 23% battery. I've tried allot of things but am open to any ideas on how to tone this down a little. Thanks
Good point. It seemed steep. I have a solution for that all day. Thanksyou probably have a wakelock. i never saw anything close to that. i would lose 1-2% overnight. there are apps to address wakelocks
Everything was perfect with this rom but for some reason even after I flashed the sensor fix zip my phone's proxi sensor keeps acting up.... the screen is turning off on phone calls and even on WhatsApp voice messages...... I already did a bunch of clean flashes (rom+open gaps / rom+gaps+sensor fix, etc) all with the same results....
Any subjections......
Crap. I just remembered that the sensor fix was for lollipop and might not work on marshmallow Roms. It sounds like it has made things worse.
Thanx for the heads-up, I was going madtrying to figure this out... I just did a restore to broken 5.1.1 and flashed the sensor fix so the phone is back to normal.... I don't know why it does it only on CM MM because on Broken MM the proxy sensor works fine... go figure...
Yeah do that lolHmm all broken mm builds proxy still bugs out for me. Sometimes its just incoming calls, sometimes its just if I click a contact, sometimes its just the dialer, but now on latest unsupported build its every incoming call. Maybe the 5.1 sensor zip I flashed ages ago isn't being wiped for some reason.
Really I don't know why the hell google or whom ever removed call settings>additional>turn off proximity
Also bugged on PAC MM but someone said they got it working with the broken mm sens flashed over it.. Which doesn't work for me, at a loss. I'd rip the thing out if I knew it wouldn't just constantly be black after that. I also read someone coated the inside of their MM nexus prox sensor with foil and that fixed it for him, but taking this specific phone apart seems more of a hastle instead of just dropping back down to 5.1
Yeah do that lol
Well, I guess my proxy sensor took a dump after I flash that sensor fix zip... maybe it was just my phone in particular. Now I have the sensor problem on everything I flash, I mean any KK, LP or MM rom. Hell,even on all my system restores...
I posted a fix for the sensor and bluetooth issue for CM13.
For the sensor issue fix. (screen stays black when ear is removed from the phone while on a call)
You must have already flashed BrokenOs 6.0.1 and have your TWRP backup or simply download the ROM. Once your inside the ROM you can use root file explore to navigate to /system/vendor/lib.
Locate these two files (libsensor1.so and libsensor_reg.so) and extract them.
What I did was use zipme apk to create a flashable zip. or simply copy the files and paste them in your CM13 ROM. (/system/vendor/lib/) change permissions to match system . Reboot and test.
Bluetooth fix . Again I extracted the bluetooth.default.so file from /system/lib/hw/ from MY STOCK 4.4.4 backup ROM.
Lastly im using the BrokenOs 6.0.1 kernel on This CM13 ROM..
changing the zImge only and also the lib/modules .
Hope this helps ya..
My cm13 ROM is 100% stable now. not one issue to report
Great ROM
That is great!! I'll follow up your method in a bit.it works as it should
when I flashed the flamingo zip it only worked for a moment then the fix goes away.
That's when I did my method and sensors are perfect
I have the Zmax Pro now and liking this phone more than the original Zmax.
