dfuse06
Oh I got the UBERTC 7.0 on broken. Seems good to me. Better than hammerhead at least !i just check the time when i see the battery 1% down i think like 1% per 2 minutes i think
Flash broken os or build a kernelHow i get ubert 7.0??
How i get broken os??Flash broken os or build a kernel
Google PlusHow i get broken os??
TyGoogle Plus
Let hope he can find it lolGoogle Plus
Rename the picture folder to picture2anyone got screenshot working?
It was that simple for meIt might not be that simple. I once had a problem where that didn't work and I ended up having to re flash the rom before I could take screenshots again.
I tried renaming /sdcard/Pictures to pictures2 then I just deleted Pictures and Pictures2 and it still wouldn't save them until I clean flashed the ROM all over again.
I figured out the fix for the Bluetooth connection problem.I would really love to keep running 6.0 but the constant dropping of connection really sucks. Bluetooth works when it wants to (on 2 different car stereos). Navigation works intermittently on google maps and reboots with Waze. I also noticed that the signal seems weak inside the house. Anyone else having the same issues? Any fixes?
So what is it?
... ADDENDUM TO PRIOR POST...
Unless I've done something wrong, yes, I've tried all the APN fixes/resets/clearing/reboots/manual adds/etc.
