Lordvincent 90
It's ONLY compatible if you already have cm7 installed
It will not partition your card for you
It only moves the apps to the PRE-EXISTING partition, on a cyanogenmod based ROM
To partition the card, boot into cwm, select advanced, then partition sdcard THIS WILL WIPE THE CONTENTS OF YOUR CARD
