Thanks for the input!
Tried kotakernal on smartassv2, and it seems to be doin good now!
Any chance we could get FUSE support in a kernel? FUSE: Filesystem in Userspace Would allow you to mount other filesystems and stuff, very useful.
ROM has been running flawlessly until I added the following Build.prop Tweaks-
http://androidforums.com/galaxy-pre...peedtest-net-results-after-couple-tweaks.html
ro.ril.hsxpa=2
ro.ril.gprsclass=32
ro.ril.hep=1
ro.ril.hsdpa.category=28
ro.ril.enable.3g.prefix=1
ro.ril.htcmaskw1.bitmask=4294967295
ro.ril.htcmaskw1=268449905
ro.ril.hsupa.category=9
ro.ril.def.agps.mode=2
ro.ril.def.agps.feature=1
ro.ril.enable.sdr=1
ro.ril.enable.gea3=1
ro.ril.enable.fd.plmn.prefix=23402,23410,23411
ro.ril.disable.power.collapse=0
ro.ril.enable.a52=1
ro.ril.enable.a53=1
ro.ril.enable.dtm=1
Now I have no service with Roaming Indicator Flashing triangle?
Is there some conflicting code above with this CM7 build? :beer:
ro.ril.hsxpa=2
ro.ril.gprsclass=32
ro.ril.hep=1
ro.ril.enable.sdr=1
ro.ril.enable.a52=1
ro.ril.enable.a53=1
ro.ril.enable.dtm=1
OUCH! I was never successful at getting any of those speed tweaks to work for CM7. Fortunately I really never need them. My speed has been pretty good so far with the Prevail and now with the Marquee.![]()
+1 on what biker is saying. I had a long conversation with hroark13 a long while ago about all the different tweaks and he said he added every single one and valued them up to the max and if you discover some that are not added it's because they did not work with cm7 or the phone or something but he most likely tried them all out before releasing the final release of this.. my speed has been pretty good as well (considering that we are on a pre-paid 3g network). been exclusive on CM7 for well over a year now and couldn't be more happy at what this crappy little prevail has become.![]()
It's the loaded version Wetbiker posted on page 56.
If you use Titanium Backup, which i do. I use it to restore the APP ONLY. It saves some time if you have a lot of apps. I havent ran into any prolems unless i try to restore app and data.
If you are using S2E, make sure it's set up and working properly before attemping the restoration of the apps.
Thats what i meant brother but you explained it better... lol
READ EVERYTHING BEFORE STARTING YOUR INSTALL!
I am doing this for you guys because I do not think that Hroark would mind since he left his links up for us to use. You need to get this now because if he contacts me and says remove it, you can best believe I will take it down immediately.
This is the full version of CM7 with the ADW launcher. All removed apk's have been added back including the theme installer. I advise using the non-ext. kernel by Kato and using S2E. If you decide to use the themes, your phone will more than likely lag if you do not.
CM7 FULLY LOADED
CM7LoadedthankyouHroark.zip
Here is a TUT on how to install S2E.
OK, flash CM7 then go in to CWM and do a factory reset, clear cache, then clear the Dalvik cache. Reboot and give the phone time to fully boot up.
Add the Kernel to your sd card, then go back in to CWM and flash the kernel. Here is the kernel to use. Reboot after you flash the kernel.
katokern_b0.4cm7-no-ext.zip
After you have rebooted, give the phone a minute to fully boot up then go back in to CWM and format you sd card. If you are running anything below a 4gig card, select 1024m as the partition. For 4gigs and up I suggest using 2048m as your partition. You will not need anything larger than that I would think. Always select 0 as your swap. Format the card and let the phone completely boot up.
Then sign in the the market and download S2E. Open the app, tap the bottom left tab of your phone and it will open up the S2E settings. Make sure that all the boxes are checked then reboot. After you phone has booted back up, open S2E and check all the boxes except data/data. You phone will run faster when it's not checked. Go ahead and reboot your phone again.
You're done. Go enjoy CM7 on your Prevail (thanks to Hroark) and make sure to hit the THANK YOU tab on the very first post of this thread!
Thank you Hroark for leaving your links up.:shakehands:
S2e is totally free... The only 'pay' versions are the DONATE versions... And they are empty apps, strictly for donations...
"Then sign in the market and download S2E. Open the app, tap the bottom left tab of your phone and it will open up the S2E settings. Make sure that all the boxes are checked then reboot. After you phone has booted back up, open S2E and check all the boxes except data/data. You phone will run faster when it's not checked. Go ahead and reboot your phone again."
I had that problem too. I fixed it by repartitioning my card after installing s2e.
