How do I enable more than 3 home screens?
+ 1 for ADW EX.![]()
hell yea i love adw ex
Me too. I've tried other launchers but always end up going back to ADW EX.
The only bug is you have to turn off wifi to download picture messages.
The advantages are all of the customizable features, like the theme chooser engine, the status bar tweaks, the performance tweaks, the built in data2sd (no setup required), e customizable lock screen, the list goes on. Just Google 'cyanogen mod 7 features' or something or that nature.
IMHO its just as fast as ctmod, but has so many more features. Give it a shot. Worst case scenario, you restore your ctmod backup.
I have a post somewhere with what I consider the best way to install cm on your prevail
Edit- here it is
Help installing CM7 on Prevail - Android Forums
I still haven't been able to get S2E to work, I did not try flashing anything as outlined after my last post. Can anyone give me some simplified instructions to try?
I was surprised to see my phone had no trouble downloading a MMS over wifi the other day, any idea what causes it specifically? Or could it have been that the wifi disabled itself when the phone locked?
I have luck some times with MMS downloading while on WiFi... its hit or miss. Iirc, its related to the rom not correctly establishing the PPP connection needed.
For the most part I am preferring working CM7 to working CTMod. I would say on average it runs better while looking better, however I've been seeing my phone default to 1x instead of 3g more often recently.
you are seeing the true reading with cm7. The stock boost rom (ctmod is based off the stock rom) is designed not to tell you when your are on 1x. This is to avoid annoyed customers calling and complaining![]()
Only other thing I liked better in CT was the call history, which I'm guessing was because it was based on a newer android version?
actually, cm7 is running a newer version of android. Ctmod (again being based of the stock rom) is running android 2.3.5, cm7 runs android 2.3.7 they just use different dialers, and hence display the call log differently
Lol! Well I can say that part of your battery drain is related to the governor being on performance by default. You don't need a voltage app to fix/change that.
If you go to settings>cyanogenmod settings>performance you can change the governor from there. (I prefer interactive or on demand)
As to s2e, I'm out of ideas... it worked for me. If anyone else has an idea, feel free to chime in.![]()
I totally agree with you. I have found that in the long term having swap enabled would bog the phone down really bad. The only solution was to swap off, swap on, which would fix it for a while but it would end up the same.
Why does it work better with ct? is it the kernel? Hey LV, tried cm long time ago, and have always been a ct guy! Thinking about trying again and what might be the best setup? Thanks! In ct the ssm is so fast and in data it is slower but has alot of storage/data room. How does cm compare to those? Also in ssm I always have about 140 ram and in data no matter what I have 100-115 only running, Why is that with everything the same? I just don't understand that?
With the apps I have installed, I average ~130-140 free. YMMV depending on what you have running in the background.
If you look back a few posts, I have a link to a thread containing some posts regarding the 'best' setup for cm7
Not sure why the swap thing works better on ct.
probably because kouma is a genius
I personally use katokernel-ext... some prefer to use the non-ext kernel and s2e to for app management.
Then sign in the the market and download S2E. Open the app, tap the bottom left tab of your phone and it will open up the S2E settings. Make sure that all the boxes are checked then reboot. After you phone has booted back up, open S2E and check all the boxes except data/data. You phone will run faster when it's not checked. Go ahead and reboot your phone again.
You're done.
! Is there a way to fix this without doing a full reset?I installed S2E and checked all boxes and rebooted. The phone is stuck on the android screen over 15 minutes and now it has a blank screen(it has been about 25 minutes), when I touch the screen, the 4 buttons light up but the screen stays off. I can get into Recovery! Is there a way to fix this without doing a full reset?
Restore a backup that you should have made? As you progress and things are working good keep making bckups so when a problem comes to you can restore a backup and start where last left off and not all over again.
... Something that I should be DOING
I went into recovery and reset the Dalvilk cache and the other cache. Now I have the grayed out boxes in S2E...Backup... What IS that... Something that I should be DOING
I fixed itI went into recovery and reset the Dalvilk cache and the other cache. Now I have the grayed out boxes in S2E...
If you play around with it you'll be able to get it where you can make your selections in those greed out boxes. It took me several tries before I got mine working again.
