It seems that every step we take foward we get knocked back 3 steps and we are not making progress.
I am starting to lose my desire to work on this thing.
I have a hard time telling what is causing these problems, if it is a problem with the ROM itself or with something that someone has added or installed.
If anyone brings up any new issues I want you to list what your configuration is, and what process you went threw to install the ROM and hot fixes
If you are installing 3G and RAM optimizing scripts, or apps that change the way the phone works, then your are not testing the ROM, you are testing your MODS
As far as external storage, yes we need a solution I prefer S2E but if it is causing issues we need to use something else. We need to get the process down for how to create the partition, what size it should be, and how the app can be configured. But I wanted this thread to be about fixing CM and not external storage.
Most of the posts in this thread are about things added to the ROM and not fixing the ROM itself.
Being that your are testing a beta, you should be giving your current config, If your current config has not changed since the last time you posted it, just point to the post that lists it. You should also be explaining how I can reproduce this issue on my phone.
