no i dont but why would it be my sd card
well when you make changes and such, are those settings being stored on the sdcard, because I am not too sure
I'm at the house now. I'll test it tooI found an issue with it I will make another one soon
yeah I see what you mean. I was actually using your source to do some test compiling( just learning) and my results came up similar. New RILs wouldn't show MEID. I wouldn't call it a dirt hack. I think it's quite geneius how you made it work. Even if it's not official. I was able to compile a working ROM but not useable yet. certainly not like yours. No intention on putting it out there even if it was perfect. just trying to learn what you guys already know. maybe sometime in the future enough of us can make it official somehow.... all I can do is try.not sure if that is gonna happen
I had to mod 2 files that normally should not be modded, and being I am not a coder, I probably did it in a dirt hack type of way
I had to MOD this file from the start to get the MEID to show, I could not get CM to work with the new RIL file, so we are still using the Froyo RIL
https://github.com/hroark13/android...ndroid/internal/telephony/cdma/CDMAPhone.java
With the new kernel the battery/power status was not being read along with other issues, but I modded this file to be able to get battery/AC to work
https://github.com/hroark13/android...ces/jni/com_android_server_BatteryService.cpp
I dont think they will want to adopt the changes
It may be linux based but Android is almost entirely a diffrent animal
My settings suddenly began not to stick... took a reboot in airplane mode to get them back working...
here is a cleaned up init for those who want to test for me
flash with cwm
cleanedinit3.zip
here are the lines that have been removed from what beta35 has
on early-init write /sys/block/stl12/queue/read_ahead_kb 4 write /sy - Pastebin.com
Testing now will post summary when done also is there anything I'm suppose to be looking for? Besides fcs and bootloops?
did u fix it the kernal? what should we be testing for?
just kind of make sure all hardware related stuff works
Ok but I forgot to post this I'm still fresh with cm7 3.5 hf2 and the volume for in call does not work with headphones or speaker just thought I put that out there
works for me
Installed 35 rom
hf2
and my new init (which should not effect this)
called my self from land line
and tested volume with headset, speaker phone, and head phone, but they are head phones with no mic
what was you install procedure, and what other apps, settings have you done?
No mods or tweaks just ebuddy Pandora filemanger phandroid app Facebook pretty Mich it I installed awd ex as well missed with stats bar settings under cyanogen I used a mic enabled head phone set. But my phone was running slow from the CPU governor
I will try again and see if its working
*side note* just did ur flash everything works just fine aldou I did not test s2e because I don't mess with that stuff
Install guide
Wipe factory/reset
Flash cm7 3.5
Flash hot fix 2
After that is apps from my SD card so o don't have to.download from market
On testing mods
here is the current audio driver we are using that handles this stuff
https://github.com/hroark13/android_device_samsung_prevail/tree/master/libaudio
I may have a headphone with mic to test but i will need to look for it tommorow
Just tested again seem to work fine maybe it was were my phone was lagging a lot had to many things running I noticed when u run a lot of services including music its laggy to turn it up or down same with the calling part for me maybe ill do another fresh install and test my method lol
tested, everything seems to work fine
ok i got cwm to update. i had it in the right place but i didnt extract the update zip. lol must have missed it. now to try cyanogenmod. do i have to make another back up if i already did it with cwm 4?![]()
I just updated my git yesterday with all the new beta 35 stuff
everything is up to date except the init.sph-m820.rc cleaning that I am doing now
are you using s2e ? or a2sd
are you on hf2
did you have issue on hf1
do you know of a way i can duplicate on my phone this issue
Yes I am using s2e... it seems to break after a some reboot... does not happen often tho.... restoring setting storage data and app on titanium also fixes...
And I did have this issue with hf1 but it seemed more severe... happening like every other reboot...
