Ok I got my MMS working now
I redownloaded the 3.5beta zip and hotfix2
reflashed cm7
and hotfix2
the same way and now it works perfectly
I took me 3 times doing it the same way before I got a good flash
I think one of the files were courrupt or a bad download or something
idk, I just know it works now.. 3G, Wifi, SMS, MMS, all good...
I noticed my MMS was a little messed up too.
So, mavrikmeercat, did you have to restore the stock rom before re-flashing CM7 and the hotfix2? Or can you just flash both over the current roms?
Fresh install:
Stock rom with gb ejo6 update 2.3.5
Then:
CM7 HKs beta 3.5
Hf2
Cleanedit3
Tried with fix permission and without fix permission
Video screen over exposed and can't be adjusted.
Camera settings that don't work:
Solarize, posterize, aqua. "Not a deal"
Double tap camera or video screen and get fc
How do I get proper sound from speaker phone while in a
Call, it's too low on my end and comes through front and
rear speaker at the same time and people on other end get
feedback.
I've read in some posts where some of you say you don't have
the speaker phone issue during a call and that's great but I do;(
I have tried all sound settings on phone from system/sound/ even
Dsp manager etc. My head phones work proper.
This Rom is near official for me minus a few bugs
that I'm sure will be ironed out soon as I'm led in
the right direction to repair-Camera -Video and
Speaker Phone.
Thanks to Mr. Hroark and all of you who have and
Continue to help this project become a done deal.
Thanks to you all and much love from Houston, TX.
Would really like to be able to donate but I am currently
unemployed. Even if my service is interrupted I will still
have the pleasure of having HKs CM7 Rom in my phone.
Thanks Guys!!!! : )
Does anyone know if this even works?? Not worth reading every post. He has updates and fixes all over the place.. Makes no sense not to put out a change log and just keep updating the original.
Then a list of fixes under it.
Thank you for posting the links. I've tried re-installing for the second time now, but I'm still having a couple problems. It took someone else three times before it was perfect, so I'll try these files and replace the ones on my sdcard.Sorry but if you can't read then you don't need to use it. Not to be rude but its fairly clear if you read it. Yes it could be better but still whats it matter if its not 100% clear. He has a change log and all info that is there are instructions.
FYI the files listed (currently) are:
CM7 Beta: cm-7.1.0-HROARK-beta35.zip
Hot Fix 2: beta35_hotfix2.zip
Not that hard, open the 1st file and use the files from the HF to overwrite the original files and save it.
Boot into CWM
wipe data/Factory Reset
install zip from sdcard
choose zip from sdcard
cm7_HROARK_3.5beta.zip or something to that effect
choose again
let run
install hotfix2 the same way amd reboot
can u put resident evil boot animation on this mod
dont go to 12. It can be bad..Somebody said it causes bootloops in the first posts I got mine at 32 and its much smoother. haven't had much time to play around with it too much.Has anyone been playing with the dalvik can heap size? Seems like turning the heap down from 64 to 12 or 16 makes the phone smoother and a better multitasker
the animation, yes. The boot sound, no. Boot sounds are not enabled in this ROM(yet?)
Animation is located in /system/media. Flashing the zip in cwm SHOULD work, but if not, just extract the bootanimation.zip from it, place it on your sd card and copy/paste it in the appropriate folder
Animation = yes
Sound = yes
I have used bac lite from the market installed the sound lib and picked a song I've been doing this sense shabbymods
Now I'm running cm7 hf2 with nexus custom boot with beanth the massacre sound so don't say no
has anybody else noticed the white balance is set high and cant be changed when switching to take a video in camera.apk or is it just me
