BiLlYsIlNeS
I followed the instructions exactly and my install went without any problems. I was nervous about this mod because the instructions seemed like it was going to be hard but it actually wasnt at all.
A New issue with cm7 I found when puting my headphones In the phone shows the little pair of headphones on the notefaction bar on the top bit the music plays through the phones speaker I think it's cm7 cuz when i was running CTmod it worked fine
Ok so my WIFI is acting up--i know you have to toggle it after new connection, but now it wont even connect---odd or it connects for few seconds then dissconnects
you guys must be doing something wrong the only problems for me is the camera.apk a lot of the settings within the app don't work, camera button opens the camera but wont take a snapshot and when switching to video the white balance is set very high and cant be change.
Good now with mms. Had to revert to stock factory reset and reinstall
WHat stock version? i did GB and did not work, and frankly tired or reverting phone
Enzo, try a fresh install and flash hf2 WITHOUT booting first, then all other steps as normal
ok i will later need phone ATM- is it normal for phone to go from99/100 battery to 94% after a reboot? im pretty sure it does not take 6% battery to reboot
Mine does that all the time, but sometimes it doesn't... I guess it depends on how much it reloads when you reboot![]()
has anybody else noticed the white balance is set high and cant be changed when switching to take a video in camera.apk or is it just me
ok thanks dudeYes... the video camera is over exposed
CM7 Bets3.5
HF2
No scripts
No Mods
This is true. Cant find the link again to post but he's exactly rightI was reading somewhere about this, I'll try to post a link. But from what I read, the battery will charge to 100% and then will not charge again until the battery drops to 90% at which point it will recharge again to 100% and repeat. (this is not reflected on the gauge in the notification bar) this is why you sometimes experience sharp initial drop in battery. A reboot just allows the gauge to show the actual charge on the battery.
Same here trench.. Overexposed. Just to confirm.Yes... the video camera is over exposed
I had these problems as well with wifi. I was able to fix it by flashing a fresh install and hot fix2 and NOT fixing permissions. Wifi works perfectly now.thats what mine does and also i have the same problem with mms
so should i do a factory reset then. the directions are kind of hard for me to understand because you have to look at 2 or 3 different post to get everything.This is true. Cant find the link again to post but he's exactly right
I am having the mms issues as well. I think I've tried everything but to no avail on this. This may be something hroark might have to address after the holidays. When he has some time again. Not a big issue for me as long as sms works I'm good.
