Huzzah the thread lives!
@RedMurkal: Are you sure you installed the mapfix? I had your same problem till I put the updated kernel+fix. Since then I've never had any problems with maps and nav.
Can you list the steps you took step by step. I may be able to help you![]()
Guess that will teach me to post before looking at the new beta's![]()
The mapsfix is not needed with the new OC kernel which he was referring to . Only with stock CM7 beta5 .![]()
Yeah but I'm not entirely sure if he wants to remain on the OC kernel or use the stock one. He didn't specify since he said he removed it when he installed the kernel+fix.
You did mention that the OC already has the fix in it. If he wants to use that then he doesn't need the fix like you mentioned. However, if he doesn't want OC then he's going to have to use the kernel+fix.
The strangest part is that judging from his response, it appears he still has issues with map and nav even with the fixes. Which I find highly unusual.
I've been a CTMod user since it's first arrival. I've been wanting to try CyanogenMod since it first debuted as well, but have never switched over due to it's status of still being in beta, so I've been waiting since it's first initial release for a stable build. Is it worth waiting for CyanogenMod to come out of beta, or should it be okay using CyanogenMod as it is right now?
I run each of them and they both kick butt !![]()
Where is the link for gapps? Don't see one in the OP. And what about these fixes I keep hearing about? Is there a build with them included? I notice this, like every other ROM for this phone, is on EXT4 (which is horrid considering EXT4 is the most unreliable file system I've ever seen for android devices) is there at least a zip for enabling journaling for cm7?
As for the Gapps in the OP , you probably need to talk to Hroak about that . As for the fixes , all the fixes from the past beta's are included in beta 5 . Really the only issue that still exists is not getting MMS over wifi .
I'm running CM7 and KatoKernel 0.2 . I'm also running the S2E app until the data2ext Katokerenel kernel is made . I'm very happy everything .![]()
There are other fixes I've run by in posts. Something about maps and other things? These should all be updated and included in the build. Gapps should "always" be included in the OP of a cm7 build, even if it's a self kang released public. MMS over wifi isn't a bug. It doesn't work on AOSP unless a workaround is built in seperately to temp activate 3g/1x data only when sending/recieving/downloading the message.
im pretty sure you can get most gapps for cm7 from the market excluding a few..i thought cm9 was the only one you had to add a gapps package for?
atleast with cm9 on my gtab you have to add them...but im not sure
Sent from this Gtab 10.1 using Tapatalk 2 Beta 2
Really it should be for any AOSP as legally your not suppose to include it in a publically released AOSP build. That's why there's a gapps package in the first place. Something to due with Google's terms. Thanks for the replies.
