Root CyanogenMod 7 Unofficial Beta 5 02/20/12
Someone BORKED my prevail doing something "illicit" anyway only the phone was borked and I don't care about the phone but made system unstable short batter reboots.
odin'd in the CWM did your modem update then your CM7 rom
Fatality. Flawless Install. Nice job.
MAN its so smooth and fast its crazy. I am just going to use it as a digital dash in the car.
one issue (NOT related to your rom) it still reboots on me. something he did during the extract clone whatnot borked the phone hard core.
is there anyway I can simply DISABLE that portion of the device so it stops messing with the system?
maybe something I can "flash" to undo whatever damage he did? I don't need it to work as a phone only to work over wifi.
You're going to have to be more specific in what he did, and what's breaking.
If it's software based, I see no reason it couldn't be fixed. I would also do a complete format/delete to 0's on your sdcard just to be sure it's ok (actually I would test without any SDCard to verify it's not causing any issues). I would also go through and format everything on the phone that I could through CWM. Then I would do an odin to stock and try it.
Have you tried using Odin to restore the phone to a stock rooted image ? If not , I would try that .
@Hroark: Hey my friend is there anyways to turn back on the lock screen when you are in an incoming call? I keep hanging up people accidentally with my face because it reacts to the 'end call' button on the screen. Normally I didn't have this problem before as I would just press the unlock button or double tap the screen.
Is there anyway to reactivate this ability? I've been reading up on CM7 threads and there is supposed to be some sort of menu called (-> settings -> call settings -> In-call touch UI) on CM7 to do it but I can see it.
Is there an older Phone.apk I can use or anything I can do to put it back? :(
Whenever I send long text messages using Handcent SMS, the recipient gets a jargon of letters and symbols, not my original text message. Has this been addressed yet?
That's a known issue with certain versions of Handcent including he latest one which is super laggy and bloated. Just look at all the hate comments for version 4.0. ;)
The problem is not always the OS it can be the app as well! :D
Handcent>settings>sent settings>split 160> simple split
I think he was referring to the recent problem that Handcent has been having where instead of sending the text that was supposed to be sent the receiver gets random text and such. It could be attributed to the splitting of the text messages. Though I've been reading more and more people are getting this problem with version 4.0 of Handcent. You send "Hello how are you" other end gets "JAS73^GF#@&*".
I only had that happen w/out the split... And he said with long messages... Just tried a 4 page text, went through fine...(newest version handcent)
Ps didn't mean to quote you in prev. reply
lol silly don't worry about :) Were both just trying to help him out!
Hmm nevermind seems that it's native to CM7. I thought there may be a way to implement this or at least add something to CM7 that would lock the screen during a call. I could have sworn I've seen it before though when I was using it. >.> I wonder if there is any other phone app I can use that does this.
It is quite annoying to have your face accidentally press buttons on a touch screen during a call. Like I said half the time I accidentally press 'End Call'.
Optimus sorta answered this here: http://androidforums.com/samsung-ga...revail-press-lock-key-unlock.html#post3774713
Unless you can give anymore advice Hroark not sure what else to do.
Same here , only time I've had the problem is with long messages when not using the split . Haven't tried with the newest version yet though . I'll have to give that a try . ;)
Looks like Hroark gave up on this rom :( There hasn't been any responses from him in some time. Looks like he moved on the ZTE Warp. Oh well it's still a great rom :)
He stated that deving for multiple phones isn't going to happen... It's up to us now. Lol. (not that there is really much to fix... Just mms over wifi, which i understand is an aosp thing)
Heh I'm alright with that. Like I said before I still think this is a great rom. Oh and btw that MMS over wifi thing really isn't that much of a deal. I just turn off wifi; if and when I ever get an MMS and I'm on WIFI. Not a big deal ;)
I look forward to the work he does on the Warp. Who knows maybe one day when I'm not poor as sin, i'll upgrade my phone.
Thanks for the heads up though I don't recall reading that response from him in this thread. Then again it is like 2000+ posts long LOL!!!
I did not give up
I have just not been able to fix the MMS over wifi issue
I am also trying encourage more people to come out with fixes and stuff
It is true that I am doing dev work on the Warp, that does not mean I stopped on the Prevail
If I have anything really good to contribute to the Prevail I will release it.
ou
I did not give up
Most of the stuff I do for the Prevail, is to provide tools and starting points for other Devs to work on
I like to give crucial pieces of the puzzle and let you guys figure it out.
Did you know that Kouma probably would have never messed with Kernel stuff unless I dragged him into it
Did you know that Bloodawn did not think he knew enough to do ROM development until I, talked him into it and brought him in on the secret CM7 project that I had.
I do not want to spoon feed you people, I want you to learn how to do this stuff yourself
There are quite a few people doing development work on the Prevail, and you guys have a lot of options, I like to think that I was a big part of making that happen
The Warp people need help, they asked me for help and donated a phone to me, and I will help them
I will still help the Prevail community
I will be doing the same thing for the Warp people, trying to encourage others to develop for that phone
ou
I'd like to share with this community that I'm starting to develop Roms, edit and Mod kernels, create scripts, porting things like CWM to a phone, making Odin work on a phone. compiling cm7 and porting it for the Transform Ultra.
as well as all kinds of other stuff.. i can adb shell and push like a muth..uh haha just sayin :p
when I first got my prevail, I didn't know jack about android. Once I learned that android was linux, I had to know more!! been a linux user for years and have done some dev in that feild. I've been in these threads since interdpth rooted it and have spend months reading, reasearching, and learning from these devs here. particularly Hroark13. he has tought me just about everything I know either directly through conversation or indirectly from trailing his threads. There are others I have learned from like shabbypenguin, interdpth, new optimus, monster, and a crapload of others but my point here is that I dont think that Hroark gets enough credit for all he has done here for us and the end result is that we all have better devices because of this man which would otherwise be a peice of crap on a prepaid service.
I don't think a lot of our new commers realize all what hroark has done here and not just for our phone but also for the president, the Transform Ultra, and now the Warp. When I was reading those other threads, I didn't see any credit given to him AT ALL(especially in the president threads) when cm7 was ported to it(you know that was hroark's work), when they posted Odin, no credit!! Hroark SINGLE HANDEDLY got odin and CWM going for the prevail and spent days/weeks of research doing so. the president is the same phone with a strait talk rom and service.(where do you think they got odin and CWM from) he also made me aware that he helped interdpth port CWM to the Transform Ultra and just recently helped us get a crucial part of Odin figured out for it too. I am just taking the time to make some of us aware of some of the hard work this man has done.
Please understand that he is a very modest guy and and he is not gonna bitch about people jacking his stuff and taking credit for it. He does this because he enjoys it. period.. not for credit, and certainly not for money... a lot less people donate than you might think..
We all know that this is a open source community and when you put your work out there for everyone to use, someone might try and take credit for your work. Those are not the kind of people this community is based on. It's an un-mentioned rule of courtesy that you give credit to those who you have learned from and those who's work you have used.
that is why I love this community. I have learned so much from it as a whole and from people like hroark. I do this for the same reason as him. because I like it and my only goal is to give back what I've learned.
I would just like to say thanks Hroark13 for what you have tought me and for whatever I will continue to learn from you.. and thanks for always responding when I ask you for help. And most inportantly, Thanks for making my crappy little phone on a prepaid service an awesome device that can do just about everything that those higher end phones can do. you are truly awesome man..:D
I wasn't trying to take away any credit from Bloodawn, koumajitsu, or any other dev around here by the way.. They are all awesome. I just wanted to thank hroark in his threads and make some of us aware is all :)
No doubt man . Please don't think that I was implying that either . It's really a shame that a lot of people take all this hard work for granted and don't even take the time to acknowledge these guys for their contributions. All it takes is a click on the Thanks tab . :)
na, it's all good man. agreed
