is there a way i can get CM7 as it comes from there site? that and can i undo it at a later date to take it back?
like you just downloaded it from their website the V isnt on the supported devices list... and how do i remvoe irt if i wanna replace itRunning it on my V..
Go here http://androidforums.com/optimus-v-...wip-backside-rom-cm7-green-machine-theme.htmllike you just downloaded it from their website the V isnt on the supported devices list... and how do i remvoe irt if i wanna replace it
You can undo it. Just make a backup before you flash the rom. Do you know how to make a backup or are you new to all this?
BACKUP PHONE FIRST!!
Downloaded it, connected phone to pc, enabled usb storage, moved rom to sd card.
Boot phone into recovery and flash from sd, highlight rom, flash, reboot.
This is assuming your V is rooted of course.
I also added the stock Optimus V Rom to my sd card just in case I ever want to make the phone stock again.
how do i move stock ROM to sd
When you make a backup in recovery, it automaticly backs it up on your sd card. Say you install the ROM and a few days later you don't like it and prefer your stock ROM (highly, highly doughtful!!), you just boot into recovery and restore your backup. **Poof** your phone is now exactly how it was when you made that back up.And if you backup before you restore your stock ROM, You'll always have cm7 where ever you go. Just in case you get the itch to come back.
Go here for different ROM's for the 'V'. I personally use the BACKSide ROM you can get here.
As for the theme, I don't know.
To boot into recovery, turn off your phone, then hold volume_down + home + power till you see the white LG logo go away. Once in recovery, be sure to do a backup before you do anything else!
The theme you linked to will not work, but there is a built in theme changer in all CM7 based ROMs that will allow you to quickly and painlessly change compatible themes, which you can download from the market. You can also use UOT Kitchen to create your own theme just the way you want it. I noticed one of the themes you linked to was green, you might like my Green Machine Theme which is posted with the links to download my BACKside-IHO ROM.![]()
Correct. Please refer to the links in my first post above(#6 permalink) as this will clear up a lot of your confusion and answer most of your questions. Read,Read,Read, Then ask questions. This will keep you from having so much stress,and keep you from becoming so confused.so do i just use the backup/restore system in CWM to save stock ROM?
