bigsupersquid
Those are the good files.
Keep them on the root of the sd card and then go back to the installation instructions.
If after typing all the line of code EXCEPT FOR(reboot recovery) you get a #(weather you get the streaming line of code), then and only then can you type in: reboot recovery.
Don't forget to rename the recovery or type it in exactly as its spelled on the sd card if you cant get it renamed.
Also, using flash_image should not produce an error, if it does then don't reboot.
