Blankname7
is cyanogenmod compatible for the galaxy s2 4g and if it is can anybody post a link so i can flash it?
I am just happy for the One stop shop. It is saving my fingers a little from some of the questions.
Yes we have links to cm.. it will be in the one stop shop under aosp roms. Follow the install instructions
That's because cm wants to be on the newest android version. I don't remember you saying u wanted to be on ics. Cm9 is ics..... or do you not know you can flash any of them ? That you can go to 4.2 from 4.0
All u have to do is download the ROM and gapps and follow the install instructions on the op... You can be on 4.2.2 in 3 minutes after u finish downloading the files
Here's is a link to the ROM you will probably want to try.
http://forum.xda-developers.com/showthread.php?t=2099881
