Root Data Governor Remover
JJ_Azevedo
Here is a patched services.jar for Firmware F Deodex
What this patched services.jar does is allows you to have an un-throttled internet
This will not make your internet faster it will just let you download without reaching a certain point where your internet/data starts to lag
once you replace your services.jar you will not be able to access settings/wireless & networks/mobile networks this is not fixable so if you want to toggle your data use your shortcuts in your notification drawer
Instructions:
1 download my patched services.jar and place it in sd card
2 copy my services.jar file to /system/framework
3 delete your services.jar and replace it with mine
4 SET THE PERMISSIONS TO RW-R-R and reboot and now you are un-throttled:D
this does work on firmware f ive already tested it and it should work
THIS WILL TAKE AWHILE TO BOOT UP SO DONT FREAK OUT WHEN IT TAKES LONG
Where i got the mod from: http://forum.xda-developers.com/showthread.php?t=888372
LINKS
For Stock F: https://www.dropbox.com/s/h245u6zylwzm0ee/services.jar
For CM PG's Build: https://www.dropbox.com/s/mdweekpr9hmk0d8/services.jar
For Paranoid: https://www.dropbox.com/s/pfkm73xd283avke/services.jar
For CM Bobz's Build: https://www.dropbox.com/s/tqfm1l9fmjntv7l/services.jar
so does this make it so they can't throttle your speed after x number of mb or gb ie: i have 500mb 4g, so i should have unlimited 4g now?
you should say if this is for stock or cm in op
obviously for stock because it bootloops cm but i can make one for cm but not tonight, i'm tired.
Doesn't work on stock... atleast for me.
did it bootloop on stock? and if not you wouldn't know if it works until you used up all your allowed data for the month. if i understand correctly, this makes it so you can use the $40 a month plan but still have unlimited 4g data. if your on the unlimited plan it would have no effect.
So i have to use this when i'm being throttled? and Yea it did bootloop but that's most likely because i'm on the $60 plan and not throttled. I still get throttled on the $60 plan for tethering too much.
I wanna know how much is too much lol my lady hit the 50 GB mark on the 8 me I hit 25 still no show down
pronounced Dur Tee Dee
This is not to give you unlimited 4G. I'll try to explain...
Lets say your downloading a 2gb file. Well you know how when you're downloading you could be downing at a speed of lets say 4mb/s and then the next minute be downing at 1mb/s. This mod is to keep you steady at the top speed for the duration of that download instead of speeds going up and down.
Im running it on my phone right now i have no problems.
i should take the link down if people are bootlooping
Used bobz 5-21 with johnnys liquid port and it worked...I think. I didn't get a bootloop but it was a long boot when it was trying to ''upgrade android" with a "tap to switch apps" loading dialogue.
it will take a long boot so dont freak out
