Sms*Is it just me or does picture msm not work?
I got a soft-brick it stay in Samsung SCH RT720 Screen
Sure...I tried Da rom n its great but my only thing was no gapps were there except the playstore n wen I tried downloading some I get 492s.can u help out a Lil bit?
I have one more issue I have data but my internet browser don't see it or something kuz I data n da play store,tapatalk, n any other app day requires internet but boat is say in I have no data I even in stalled meteoweb again n still no data is goin thru those 2 apps plz help me out
Are you new to CTMod?
Yep... Now i'm using an stock back-up
How can i install this rom without problems?
Yep...
You'll need to be on req's cwm (the one with the little text...) factory reset... and install the rom....
I'm Using Req's CWM 5.0.2.7 :/
So based off dat I guess my problem was I flashed dis over oa did a full wipe but I didn't install req's kernel b4 I flashed maybe dat killed the data for my browser.idk gonna try again n a hour or so but dis time ima flash reqs kernel b4 I flash it.
Im guessing you cant use the stock kernel with this rom its either Req's kernel or that new reworked kernel from pressy4pie right?
