Philadelph
This should be a pretty simple answer, but I haven't found it while searching... So I recently rooted my Evo and am running the stock Rom with Amon RA recovery (awesome by the way). I wanted better battery life, etc. so I flashed a Kernal (backup then wiped Cache, Dalvik, etc. first) and it all went smoothly- everything is running great. My question is- should I leave the original Kernal .zip file on the root of the SD Card, or remove it? I know that when I installed Amon RA, I had to remove the .zip file after so it wouldn't keep asking to install in bootloader or whatever, but with a Kernal is it the same? If it doesn't matter, is there an advantage to keeping it there? I guess the same question could be asked for ROMs too- so feel free to offer suggestions for that too. Thanks for the great advice- Rooting has opened up a new world for me!
. Just a quick distinction - when you flashed RA, it sounds like you used a PC36IMG.zip file. Those are flashed through hboot, which is your bootloader. Those PC36IMG.zip files can contain img file(s) to overwrite the entire contents of whatever partition(s) you specify. It is somewhat limited in that respect, as it's not very selective. It's either the whole partition or not at all. In any case, you flashed over the whole recovery partition, which is what you wanted to do in that case. These PC36IMG.zip files must be removed when you're done with them, as you found out, or hboot will find it and prompt you to flash it every time you go to hboot. If you want to keep those around for emergencies, rename or move them. They can be removed, though, as you know
