Are you guys leaving 3g on? Only use 3g when you need it, leave it on GSM only when you don't need 3g.
And disable "always on mobile data".
I get atleast 30 hours and I use my phone quite alot
Have you been discharging your battery frequently?ye i am, i turn off absolutely everything. Did all the suggested tips but hasnt made any difference at all. I used to get 30 hours approx![]()
The fact it's only doing it out of airplane mode, and as you say you only have 2 apps loaded is suggesting either an app syncing frequently (facebook, friend stream, mail etc) or poor signal to your mobile network.
How much web browsing are you doing?
You shouldnt run down li-ion batteries to flat too often. It degrades them, and could be your issue.
How often have you been discharging it?Im getting alot of mixed info on batteries! The phone is only 3 months old should i expect it to degrade in this amount of time? Should i then start charging it from above 0 to 'heal' it or shall i assume that its beyond fixing and get another battery?
I let JuiceDefender turn my 3G off and on. (off when screen is off, on when screen is unlocked and you're using the phone).
Works a treat for me (yes, i know others say it doesn't work for them, but its fine for me)![]()
WiFi only if you have sleep enabled. This isn't controlled by always on data.
