Like I mentioned in my previous post , my battery life has transformed since installing the OTA update . This is with friendstream on & syncing every 2hrs![]()
Hi,
What's OTA Update??thanks.
plan to get DHD this sat.....![]()
I have had my DHD for just over a month and the battery has never lasted more than 15 hours. I have tried various tips from the forum but have had no luck.
I have a stock phone on Vodafone UK running the latest build.
Uptime Length: (How Long your battery lasted) - From 7.0am - 10:30pm (15.5 hours) < 10% battery left
Accelerator: On
3G Or 2G: Strong 3G at work, 2G at home
Wireless On: Yes at home
GPS On: No
Automatic Brightness: No - Set to around 20%
Misc: I have Gmail on autosync, mail on 30 minute sync 7am-7pm, all others on 12 hour sync.
I play several games for a max of 30 minutes and use the ebook reader for about 30 minutes daily. I also run CardioTrainer which uses the GPS and music for 30 minutes every few days.
I did have live wallpapers, stock ones from HTC, but have just switched to a static wallpaper.
I charge the phone every night and leave it charging until morning. Also I have Airplane Autoswitch running which switches Airplane Mode on from 11pm to 6am.
If anyone has any tips then I would appreciate it as it is a great phone, but I can't use it to its full potential.
I’m just getting to grips with the phone at the moment – customizing etc. Anyway the battery life is appalling! You can’t defend the life of the battery, I’m sorry, but it’s really THAT bad. Anyway…
Uptime Length: 6hrs 35min and counting….
Accelerator: On
3G Or 2G: No network at the moment as can’t get signal here
Wireless On: Yes
GPS On: No
Automatic Brightness: No – it’s way below 50%, probably about 30% odd. It’s dark but not too hard.
I have about 20% battery life left and breakdown is display 44% standby 43%.
Not good enough. You should be able to be out of the house for a whole day (at least 8-9 hours) being able to use the applications on your phone and not having to worry about your battery dying.
If you have no signal FOR THE LOVE OF JEBUS turn airplane mode on, your phone will be franticly searching for a network signal and chomping through your battery
If I do a update check on my DHD it says there is none.. 2.2 remains. I asked HTC and they denied there is a 2.2.1 update for DHD
HTC wrote:
Thank you for contacting HTC.
HTC still didn't confirm with us about any rom updates for the htc desire HD
as soon their is any confirmation about the updates we will contact you
What gives? Can i update this some other way and not via OTA?
