Root [DEV][ROM][ALPHA v2] CyanogenMod 10 for the LG Esteem 4g LG-MS910
email from BRAINZ2013
"Well sorry it took me sometime to respond but i had no data after flashing the cm10. So i just downgraded and upgraded and here i am . Now its working still no data all i can do is the 228 update . When i checked the 4363 it wont leave the cdma prl . If i think it should be cdma lte . If you can get that to change i think data will run . Now the wifi connect and the only issue is that you cant see what you are typing . And u should post that when u flash the cm10 build to get into the rom and pull battery . Replace the battery and get into the recovery and wipe only data and cache . And now get back and you see everything works fine but no data . Sorry i cant get into the irc thing i tried at home and at work nothing ..."
Hey guys, I got multi mode ril working (I assume multi, is for lte + 3g / 1x)
However netmgr keep crashing
I/netmgrd ( 2398): reloc_library[1331]: 2399 cannot locate 'ensurePropertySet'...
I/netmgrd ( 2398): CANNOT LINK EXECUTABLE
ensurePropertySet appears to be a java data base thing. I assume our cm10 uses a newer version which no longer uses ensurePropertySet...
So if anyone can figure that out, we can move on.
My phone has been lost while helping a friend tow a car. its somewhere between here and 50 miles away. Sooo... I'm sorry. But my work has ended here. Playfulgod has plenty of stuff to cherry pick. Hopefully he can get back to this phone again.
Thank you saschaelble for all your efforts. It's really unfortunate that you lost your phone, that just sucks bad! You and PG deserve much praise for bringing CM10 to the Esteem, even in it's current form. You guys (and everyone else involved in making the Esteem a little less drab with the themes, mods & roms) have made owning the Esteem a lot of fun. I'm sure I speak for a lot of us when I say Thanks, YOU GUYS ARE THE BEST!
I'm still holding out... I know the Esteem audience is dwindling but like I've said in the past, until this phone is absolutely useless (or lost, :p ;) lol) I will still continue to use it daily. When I finally retire it, without question I'ld get the LG Spirit, especially since PG is brewing CM10 for it! :D
thanks and yea, its even almost usable as a daily driver lol even with the locked bl. See how much easier new/current tech is to work with??? lol
but I will be seeing what I can do with sas's changes etc soon. ;)
they're the same phone but the revolution is for Verizon please if this is possible i need comfirmation before i do something stupid to my phone:):D:D:(
will this work for the Lg Revolution??
in its current state no, not at all. The Esteems kernel wont boot on the revo and vice versa. I will need to mod the revo's kernel src of see if the revo's config will build with the esteems src. Device tree side it just needs the prebuilts swapped out with ones from the revo and ms910 edited to vs910. I still plan to fork it to the revo when its in a usable state. ;)
