PlayfulGod
Extreme Android User
DISCLAIMER: This is a CUSTOM' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go folks, CyanogenMod 10 for the LG Esteem 4G!!! Well, let's be honest, unless you're living under a rock, you probably know what Android 4 (IceCreamSandwich) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: CyanogenMod | Android Community Rom based on Jelly Bean
- Version: 03.16.2013
- Developer: PlayfulGod
- Description: CyanogenMod 10 for the LG Esteem 4G
- Source: github
- Status: Alpha -as in not usable as a daily driver!!!
CyanogenMod 10
What is this?
This is a build of the popular CyanogenMod 10 for the LGE Esteem 4G LGMS910. This is built from source.
People to Thank
- koush - for his kickass recovery.
- CyanogenMod - for the best ROM out.
- hroark13 - for hellping me get my kernel straightened out, thanks bro.
- chui101 - for fixes I applied to my kernel for the backports.
- numerous testers - thanks for testing & keeping the faith.
- IRC - for the ongoing help and shared knowledge.
- #oudhitsquad
- #cyanogenmod-dev
- #koush
- TeamWin - for their cool recovery.
- Not much... yet
- It boots, you can look around and sorta see what Jellybean is all about.
- This is not, I repeat not usable as is, you will, I repeat will have to restore a backup or flash a rom once you are done checking it out.
- ui is much smoother than it was with CM9
- 10.16.2012
- kernel booting with kgsl working, aka no pink screen . - thanks to hroark13 finding what I left out and did incorrectly, thanks bro!!!
- 10.20.2012
- Moved to CM10
- CM10/jellybean is playing nicer.
- 11.03.2012
- Pre-Alpha release
- 03.16.2013
- RIL partially working! Thanks to requisite0 for pointing out a legacy flag I could use.
- Overclocked to 2Ghz max
- Underclock settings added as well
- Interactive governor added
- Smartass2 governor added
- LagFree governor added
- Tun.ko support
- CIFS support
- SDCard Read Ahead Speed Tweak
- SIO Scheduler
- Genlock backported
- KGSL updated
- Adreno drivers backported & lib updated
- N/A
- Download the .zip & copy to phone or sdcard (make sure 4g or wifi is enabled if dl'd from phone).
- Zip can be installed from either internal or external sd in CWM (Which ever you copied it too!)
- MAKE A BACKUP!!!
- DO A FACTORY RESET!!! - this will wipe data & cache!
- Go to install zip from sdcard
- Choose zip from sdcard
- Select cm-10-xxxxxxxxxx-UNOFFICIAL-ms910.zip.zip
- Confirm
- Repeat Steps 5 -8 for gapps
- Reboot
md5sum: ba5fac3fcafbdb7b1d307229bb3ca8a8
md5sum: 4e9e7ec3c22b0b3471bd05d62b8a659d
Donations
Official Donate link if you like my work and would like to show your appreciation and support. All donations are greatly appreciated!!
