Root [DEV][ROM][ALPHA][WIP] CyanogenMod 10 for the LG Esteem 4g LG-MS910
Wi-Fi showed that it was on but I couldn't scan for any networks. I would have liked to type in the network name manually to see if it would connect that way but the keyboard doesn't work either. My buddy made some adjustments to the zram and a couple other things, I think he said something about giving the ril more memory or something, which caused the settings to stop crashing and it showed that I was connected to the network but I don't have my service turned on right now. I dialed *228 and got the squealing and after reboot it was gone. And I'm pretty sure I heard talking in the background of said squeal. The dialer kept goofing off afterwords so I couldn't call again.
Also I tried to dial *#*#4636#*#* to check connection into and it also crashed.
I been reading some posts on the LG connect forum about cm10 they almost have everything running the only thing is their data and mms but some of them are getting data.. great work pg.. you are always working hard.. hopefully we get the LG esteem cm10 working with voice and text soon..:-)
AGH, but the motion is still getting some decent love. And I've played with the phone, even without roms its a smooth experience.
so, i flashed CM10 just to check it out, i made a back up, wiped data, etc. i didnt find anything other than what everybody else found, except that i noticed in the settings when u go to select a network type it wont give u an option for LTE, only GSM, CDMA, EVDO, and all that, so i though, "ok, it needs more work" (thanks a lot on that btw PG, im almost holding my breath waiting for this to be done, when ur done, i will donate at least half of the price of Spirit since u will be saving me that money anyways ;)) So, when i flashed the recovery img everything was fine, but when it booted up, as soon as i get network signal (which is 3G instead of the usual 4G) it reboots, so its been on a loop since i left my house this morning, the only way i got it to stop was to put it on airplane mode as soon as it starts up before it gets to the network part, wifi works fine tho, and calls seem to work fine as well, anybody else experiencing this?
Yea I am. And someone else is. Unfortunately until PG tells us an actual fix I'm thinking that maybe a flash to complete stock may work? But in reality I have no idea and that may not work.
service/data not working after restoring a backup???
Pg its great can i ask about this gyroscope dam this was a great idea and dam it doing some good great idea :eek::thumbup::thumbup::rolleyes:
Not from this cm10 if you did a full wipe and put another rom on it. And you said u performed a full downgrade and upgrade :eek: nahh its sounds like you may need to call metro and make sure numbers are correct.
