so when I had my Ascend I installed a rom with CM6, heard CM7 lagged on the Ascend....if you are workng on CM9, what happened to CM8? or are the versions based on Froyo, Gingerbread (Honeycomb) and then Ice Cream Sandwich?
Cm8 should of been HoneyComb. But the src for HC has never been released and also HC is for tablets not phones. But yea cm versions are based on android versions.
any news about cm9?
Looking forward to CM9 on Esteem!
Whos with me?![]()
You mean this?
Annnnnnd the swams of "PlayfulGod can I try it??" Start righht abouuuutttt NOW!
why no one likes honey combs?
http://www.productwiki.com/upload/image
s/post_honey_comb.jpg
Cm7 is on many tablets, but its not exactly optimised for them. The Cm crew did do alot to make it better on tabs tho.
Just a simple breakdown:
CM4 = 1.6
CM5 = 2.1
CM6 = Froyo 2.2
CM7 = Gingerbread 2.3
CM8 = N/A woulda been HC.
CM9 = ICS
Google released the HC src when they released the ICS src afaik, but is purdy much debunked now since ICS has all the best parts from both GB and HC + more.
First off, I cannot wait on this rom and are there any updates PG?
Secondly, should I flash GingerSteem for the time being and when this comes out, or just wait?
