levis rockin
Member
I gave you the link to use that had no errors. What's the problem?
Lop nothing ill try ROM in a few
thats about it atmSo has there been any status updates I missed? From my understanding the kernel issues have been worked out? My phone looks like it's running ics as it is and I can wait for cm9, I am just curious of the progress.
my phones stuck in boot loop rmo cm9 how do i get it into recovery =[[[[
Take out the battery and hold the power key and both volume keys. When the phone turns on let go of the power key but still hold the two volume keys until a black screen appears asking if you want to wipe data/phone. Press the power button 3x and you should be in recovery.
thats about it atm![]()
I didnt say thatThis... This means it's almost done <3
I didnt say that![]()
you're usually a tester so I think you would know eh???^Reverse psychology![]()
I too also received the install aborted. however i was not locked out of my recovery and the phone booted fine after words.
Dont use the link in the OP.
Use this one. This one works.
https://www.box.com/shared/static/0e60ba792523c591658e.zip
juan12456 said:do i install this just as i would install any other rom?
-already made a backup. I just dont know whether its is safe for me to try it or not. thanks
The link I posted above is a working install. Ive used it many times as others have too. The link that's in or was in the OP is the link that gives the error.
