M
ModdingMyMind
Guest
K2_CL ONLY!!!!!
Kernel Source: Click Here!
Changelog Version 2:
Changelog Version 1:
TWRP 2.7.1.0 - for 4.2.2
TWRP 2.7.0.2d - for 4.2.2
TWRP 2.7.0.2c - for 4.2.2
TWRP 2.7.0.2b - for 4.2.2 (deprecated)
TWRP 2.7.0.2a - for 4.2.2 (deprecated)
TWRP source was patched from https://gerrit.omnirom.org/#/c/6283/
This patch allows the ability to take screenshots while in the recovery. It has not been merged over to the TWRP source yet so only unofficial builds at this moment will be seen with this feature.
To take screenshots while in recovery just press both the power key and volume down key. The screen will flash. It will naturally store the screenshot in your pictures folder of your sdcard if mounted in either your internal or external.
TWRP Changelogs:
HTC Dumlock Instructions:
Code:
* From commit [URL="https://github.com/ModdingMyMind/android_kernel_htc_k2_cl_twrp/commit/86a317157a741ef12042426696e3c84eeed3e263"]86a317157a[/URL] on my github.
* Kernel built in version 2.7.1.0
* Disabled Module support
Code:
* From commit [URL="https://github.com/ModdingMyMind/android_kernel_htc_k2_cl_twrp/commit/c34ea02e20b758e78cae9f8b8bc975d268accd84"]c34ea02[/URL] on my github.
* Kernel built in version 2.7.0.2[B]d[/B]
* Added full SELinux support.
* Removed HTC write protection.
TWRP Changelogs:
Code:
[U]2.7.1.0
[/U]Built with custom kernel.
- [B]Removed custom theme and reverted back to stock theme.[/B]
- Add GUI option to change or repair file systems on individual partitions. The change is destructive so backup your data including internal sdcard first. This option should make it a little easier to migrate a device from ext4 -> f2fs, for instance. You will find this option under Wipe -> Advanced Wipe, then select only one partition and then press the Repair or Change File System button.
- Various bugfixes to backup and restore
- Improvements to USB storage handling
- Added a class to search for files to make finding the correct brightness file automatic in most cases
- Various other bugfixes and tweaks
[U]2.7.0.2d[/U]
- Added full SELinux support
- Completely removed HTC write protection.
[U]2.7.0.2c[/U]
Fixed init.rc to allow communication with binaries in /sbin.
TWRP 2.7.0.2c is built ready for SELinux, but the kernel is stock. Until they release the source I can't modify the kernel to support SELinux. This is really only needed for having 4.3+ roms but I want to include it in case the day comes and we see CM, AOSP, or possibly other sources.
[U]2.7.0.2b[/U]
Minor theme adjustment
Upgraded screenshot functionality throughout entire recovery
Note - version 2.7.0.2a screenshots are limited to only the main page
TWRP 2.7.0.2b is built ready for SELinux, but the kernel is stock. Until they release the source I can't modify the kernel to support SELinux. This is really only needed for having 4.3+ roms but I want to include it in case the day comes and we see CM, AOSP, or possibly other sources.
[U]2.7.0.2a[/U]
Built from CM11 and Omni 4.4 sources.
Extended backup options.
1. System
2. Boot
3. Cache
4. Data
5. Recovery
6. Misc
7. Firmware_radio
8. Firmware_q6
9. android secure
*** I think I listed them all ;-)
Built in AromaFM.
Implemented screenshot functionality.
Added offmode charging.
Completely updated to fit with 4.2.2.
Includes Holofied Black Theme.
TWRP 2.7.0.2a is built ready for SELinux, but the kernel is stock. Until they release the source I can't modify the kernel to support SELinux. This is really only needed for having 4.3+ roms but I want to include it in case the day comes and we see CM, AOSP, or possibly other sources.
HTC Dumlock Instructions specifically for S-On users but S-Off users can use it as well if they choose to:
1. Install the build of TWRP using your method of choice, but you must actually flash TWRP to recovery.* No fastboot booting it.* We need it in recovery so that this build of TWRP will be flashed to your boot.* This new build of TWRP has features in it to easily restore your original boot.
2. Reboot into recovery.
3. Make a backup of your phone.
4. Tap Advanced.
5. Tap HTC Dumlock. (If you don't see HTC Dumlock then you need to remove any custom TWRP theme that you might be using.)
6. Tap Install HTC Dumlock.* This will install the app and binaries needed to make everything work nicely.
7. Reboot your device.
8. Find and open the HTC Dumlock app.
9. If/when prompted, give the app root (SuperUser) permissions.
10. Tap the Execute HTC Dumlock button.
11. Wait patiently for a couple of minutes.* It takes a little while.
If your device doesn't reboot automatically, reboot it manually.* Reboot it normally.* DO NOT reboot it to recovery.
You should now be in your recovery, but your recovery is flashed into boot.
12. Tap Advanced.
13. Tap HTC Dumlock.
14. Tap Restore Original Boot.
Use your recovery like normal.* Flash a new kernel.* Restore a backup with a different kernel.* Do whatever you please!
