Saxön
After a little common sense and testing I found the LG Hidden Service Menu exclusive to this model...
The rest appear to be current dialer codes I found elsewhere that work on our phone.
***********USE AT YOUR OWN RISK***********
IF YOU DON'T KNOW HOW TO USE THESE,
YOU WILL JACK YOUR PHONE UP AND I WILL
NOT BE RESPONSIBLE!!!
*******YOU HAVE BEEN FOREWARNED*******
The following have been tested by me and work.
5689#*740# - LG Hidden Service Menu
##RTN# - RTN Menu
##DIAG# - Enables DIAG Mode (Requires MSL)
##DATA# - Advanced DATA Menu
##DEBUG# - DEBUG Menu
##TEST# - DATA Test Menu (Requires MSL)
##LOG# - syslog Info
##WLAN# - WLAN Info
##(YourMSL)# - Service Programming Menu (Requires Reboot To Get Service Again)
The following have NOT been tested but should work also.
##SCRTN# - Erases Any Info That Has Been OTA Provisioned (Forces A Reboot And Reactivation)
##CLEAR# - Reset Network Settings
##UPDATE# - Forces Activation
##GPSCLRX# - Clears GPS
##GPSTESTPRL# - Test GPS PRL File
##MRU# - MRU Clear
##SSDRTN# - Resets SSD
Before people start hammering me on the method I used to get my MSL,
I called boost customer service on another matter and at the end of the call just asked for it and voila.
##RTN# - RTN Menu
##WLAN# - WLAN Info
##MRU# - MRU Clear
