can you get into recovery? pull the battery out and hold down the volume button and hit the power button while still holding the vol dn button. Then go into recovery by hiliting it with the vol buttons and selecting it with the power button. Once there, go to wipe and wipe the cache and dalvik cache and try to reboot there. If that doesnt work, then you should reinstall mikg from scratch via the same method used to get into recovery and that should fix it. If THAT doesnt work, then go into recovery, do a factory reset and reinstall your rom. If still no dice, then theres additional stuff we can have ya try, but I seriously doubt that youll have any issues from here
let us know what your results are
Welcome to the forum good sir! Youre in good hands herecan you get into recovery? pull the battery out and hold down the volume button and hit the power button while still holding the vol dn button. Then go into recovery by hiliting it with the vol buttons and selecting it with the power button. Once there, go to wipe and wipe the cache and dalvik cache and try to reboot there. If that doesnt work, then you should reinstall mikg from scratch via the same method used to get into recovery and that should fix it. If THAT doesnt work, then go into recovery, do a factory reset and reinstall your rom. If still no dice, then theres additional stuff we can have ya try, but I seriously doubt that youll have any issues from here
thanks the phone came back on but now i have apps that want to force close. I went to htc sence and removed the default but i still have apps that need to force close. any suggestion? again thanks
