Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
My keyboard is working just fine. Yes we can dirty flash, I did at first but thought camera was broken this way so I did a clean install 2nd only to find out camera is gone period lol
Can someone tell me what exactly the GPS problem is? I am curious as I haven't had any issues with it in none of the 3 releases. Also I never had a need to use battery saving mode nor for GPS or the system as a whole.
Maybe a little info as to what happened with the camera?
Camera and GPS = kernel and lib issue I would assume. Restored the previous kernel, thinking it would fix the camera seeing as it was the only one with working camera and still no go. That's what makes me think the libs might be screwed up on top of it.
When you turn GPS on there's a chance it'll lock up and reboot your phone. There's been mixed results with it.
Bug report time! Enabling tether while WiFi is on will turn WiFi off (as it should) but when turning tether off its been rebooting my phone after trying to turn WiFi back on
Did a clean flash of the new build, was aware of the camera and GPS issues.
Other than soft rebooting a few times during extended YouTube use this build is working great.
I noticed the flashlight toggle in notifications was absent, upon use of a third party app I'm greeted by this screen.
I want to thank @Noobified and @MikeHoncho and anybody else who has worked on this ROM its great that people are developing for devices the official ROM devs overlook
First off. Thank you for this ROM .
I am having a issue though. For some reason none of my root apps are working. Maybe I'm missing a setting but I've looked and can't find one.
Any help would be great.
TIA for any help fixing this.
I updated this ROM with the new build and had to reinstall SuperSU and it's binary. You should have root restored after that.
Pardon my freshness, but do you have to be on 10B to flash this rom?
My software version is MS34510D and I don't want to go through the risks of flashing this and borking up my phone.
I never flashed anymore zips, the SuperSu apk needed to be reinstalled with bianry.
To get root: Go into settings, about device, tap build number like 5 or something times. Then back out of about device, and then there will be developer options, then scroll down to root access and choose what you would like to use root for. :) Hope I helped
Don't need to be on any particular version, just need to go to Developer Options and click Unlock OEM to open up the bootloader, install Kingroot (if not done already) and use TWRP Manager or Flashify to install TWRP from the OP. Then your good to go
08-23 01:44:23.770 E/CameraService(296): getCameraVendorTagDescriptor: camera hardware module doesn't exist
08-23 01:44:23.771 E/CameraMetadata-JNI(13916): CameraMetadata_setupGlobalVendorTagDescriptor: Failed to setup vendor tag descriptors, received error No such device (-19)
08-23 01:44:23.771 W/CameraManagerGlobal(13916): Failed to set up vendor tags: The camera device is removable and has been disconnected from the Android device, or the camera service has shut down the connection due to a higher-priority access request for the camera device.
Logcat for the camera, after that it's a bunch of Java errors. Aside from the camera not working and the GPS causing random reboots, very nice job. Really breathed some life into this phone.
Nice pull! This should shed some light on the problem
I'm having a issue with the Google Play services . Anyone have any ideas why this would be? I've tried installing it from the gapps package but it just fails to install.
New build is great! Knowing when your phone is gonna die is really helpful. :) Thank you again devs for your time and work. Camera and GPS both worked for me on last build without ever a problem (came from stock 10b... rooted with kingroot.. Got old twrp.. Then got twrp from the OP and flashed 7-12 build... Then in later days flashed 7-14 build.. Then dirty flashed this build... If makes a diff) but now both camera and gps truly do not work for me lol. Not worried because I expected them to not work upon each new build but just letting u guys know to potentially give helpful info. Phone stays less hot now too that the CPU freqs don't go cray. Thank you and have a safe and wonderful day/night everyone! -Online
@Noobified Thank you so much for the fixes. But I have one problem. Everytime I try to install the new zip from recovery, it fails, stating the following "E: Error executing updater binary in zip ' external_sd/cm-12.1-20150820-UNOFFICIAL-ms345.zip" I have wiped and re-wiped to no avail. Can anyone tell me what I need to do or what I can possibly do to install this new update? Thank you in advance.
