antonioblee1
Want to check progress? Go to github search Lept-dev ...you shall see all there projects and progressProgress?
edit: actually there is a kind of work around for maps if you need to use device GPS. Switch GPS to battery saving, find an address and when it prompts you to 'improve accuracy,' just click yes. Works every time. I should also mention that you must be in battery saving BEFORE opening maps. It seems it only crashes if you OPEN an app that requests device GPS straight away. Use battery saver mode on GPS to avoid this, then switch to high accuracy after you've already opened the app.Wow, I feel really stupid....forget every single thing that I wrote. The phone was only restarting because the gps was automatically on and that cause a constant reboot cycle -_- I should've came on to that sooner. Is there a fix for the GPS? I haven't bothered to look through this forum in regards to that.
Thank you so much. I do have one last thing though. Do you or anyone else here know where I can get an updated radio for this ROM so I could enhance my reception?
If you can get an adb server to start via usb let me know. I couldn't get it to work for the life of me. adb over tcp works, though.OK so I'm very glad to c that when i plug my phone into my computer, via usb charger, my phone doesn't crash anymore and reset so thats excellent news, just one question is how to adb, if even possible right now
Thank you!!!**** New Build 8-20-2015 ***
cm-12.1-20150820-UNOFFICIAL-ms345.zip
Credit goes to @Noobified for the fixes
Fixed:
Battery issues
CPU issues
Still not working:
GPS
Camera
Ok thanks for the info, really appreciate it, and i'll continue trying to get to workIf you can get an adb server to start via usb let me know. I couldn't get it to work for the life of me. adb over tcp works, though.
Well, the post clearly says the camera is not working..I am having two problems: I have no camera at all now (and no flashlight) and battery is dying faster than ever. I did a clean install.
I clean installed for a buggier version..... I am waiting to see if the CPU fix has fixed my issues as I often couldn't answer calls or respond to texts as promptly as I had liked on the previous release.
