Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
I had a weird problem. The battery crashed on me after a while of no problems, so I wiped and restored my stock backup. After that, every time I try to uninstall anything the phone reboots. I've wiped all cache's, reset the phone, installed the original TWRP, reset app preferences and cleared Play Store data.
Not a problem, as I'll just re-flash a stock image that I downloaded, but I thought it was weird. Nothing I've seen before. Can't wait till the battery gets stabilized, though. I love the ROM.
Again that is the version I have. I don't see it possible for anyone else using the same exact device to have different results. Same hardware and software there isn't a magic spell for this it either works or no dice.
I had similar results when I built my ROMs for the ZTE Awe (AWEsome ROM) and HTC Desire 510 (Dragon ROM) so it does happen believe it or not. I'm not sure how to help with this issue. Best I can say is wipe 3 times and give it another go. Don't forget to wipe dalvok and cache after flashing.
Maybe try installing the first ROM and dirty flash the latest?
Side note: for some strange reason my battery is being read properly out of the blue. Weird...
Why does this ROM keep rebooting my phone after install. I have the right TWRP follow all the flashing instructions including all the wipe requirements. It boots to the setup select language page and five seconds later it reboots. It is really annoying.
This happened to me, soft reboots when trying to switch from WiFi screen to gapps sign in. Just keep trying and once you pass the setup wizard the reboots should stop.
I had the same results from the first build.
Battery issue fixed, I can leave the phone unplugged and it stays on.
Been fixed since latest release. Seems it needs to sit for a while before it actually sees the battery. Occasionally the battery stats will properly read battery levels as I use the device but I find my device dying around 20% mark. And charging doesn't raise the battery readout until a reboot. Its unreliable for now and I'm excited for the next releases
Did you do anything special to get the battery to be read properly?when unplugged,my device wont decrease in percentage...it just sits the same...charges dont register until after a reboot.then it stays at 100%...
Nope. Its just broken and half works when it feels like. Its broken because CM.
This is very early development, so be aware these issues are very common. It'll be fixed later
I've found a possible GPS temp fix. Normally, if location is set to high accuracy or GPS only, nav apps reboot the phone. I changed the mode to battery saver, which isn't supposed to use GPS. I started up Maps and it pin pointed my current location exactly, like GPS is on when it isn't supposed to be.
I then switched back to the other modes and the phone started rebooting again. Any other time any phone that I've had that tried to find my home location just using tower triangulation (battery saver mode) has obviously been miles off, so the GPS has to be on in this case even when it shouldn't be, only the phone is only stable in that mode.
Be sure you have the correct TWRP installed (The blue themed one). Make sure you are performing a factory reset before you flash
