I noticed something about the display and I dont know if thats normal : When you press the power switch the screen sorts of 'unsmoothly' dims first and then turns off. Is it normal or just my Fascinate?
I am using the power saving settings in regards to the backlight/led/whatever. It's not smooth. It is a bit annoying, but I'd rather save some juice now than have my screen blazing bright all day long.
