gamer30168
Get so hot that the screen and apps freeze up and sound quits? Mine does even when im not overclocking......are the thermal controls as good as they should be on custom roms?
Weird. I understand there are variations in tolerance. Mine will run at 2.2 gigs....if i put it in the freezer
on my esteem (the now dead one) it had heat issues due to a bad sdcard once.could be a faulty battery?
I didn't even know that was possible.on my esteem (the now dead one) it had heat issues due to a bad sdcard once.![]()
it is, I thought it was the battery n bought another one and it still got hot until I took the sdcard out.I didn't even know that was possible.
When I tether it gets warm but I guess that's normal on all phones.My phone pretty much doesn't move from 77 degrees. Guest I'm lucky![]()
